VPN config
rhltechie
Hi All,
I have added a new network that my vpn users are allowed access to. I see it in the config and I also added the routing in the asa as well but still cannot get to the new network. is there something I must clear before this is allowed?
TIA,
R
desai.jaideep
Level 5
Level 5
Can u post both the configs?
JD
access-list outside_cryptomap_dyn_20_1 extended permit ip 192.168.x.0 255.255.255.0 192.168.x.0 255.255.255.128
route inside 192.168.x.0 255.255.255.0 192.168.x.20 1
route inside 192.168.x.0 255.255.255.0 192.168.x.1 1
Does the destination network know how to get back to the ASA for the VPN Client Pool of IP Addresses.
Do you see decrypts on the ASA for the VPN Client that you are testing with or no decrypts at all.
Also, try clearing the xlate and see if that makes a difference.
Arul
