VPN from router to PIX
KlediBodinaku24
Hello
I have a Cisco 1811 router and a Cisco 515E PIX and I'm trying to encrypt the communication between them.
Now when i connect them to the same network everything is working fine.
My case is that i have a router in the middle of those which should not change anything, but this does not happen.
I can ping the 2 peers from each other and i have allowed the IP and ICMP from both sides.
I must mention that the remote network is a subnetwork.
I will atach part of the log.
Any sugestion?
Kledi
owaisberg
Kledi,
Can you post your config from PIX and the
router ?
Thx,
OW
Thanks for being ready to help me OW
Problem Solved
