XOT Log Message
e.hoehn
Does any one know what this log message could indicate (it must be new in IOS 12.4(12):
Invalid decrement of XOT in-use VC count 0
It apears right after the following messages:
[192.168.0.1,3674/172.16.0.1,1998]: XOT I P/Inactive
Clear (5) 8 lci 1
Cause 0, Diag 255 (DTE originated/Unknown
diagnostic)
[192.168.0.1,3674/172.16.0.1,1998]: XOT O P7 Clear
Confirm (3) 8 lci 1
paolo bevilacqua
Doesn't seem malign. You had 0 VC's, a clear comes in, (for which VC I'm not sure), that isn't possible, so the message.
Hope this helps, if so please rate post!
At the time, this message occours, there are actvie VCs and these messages are printed very frequently. Any other idea ?
Then is a cosmetic bug and you should open a case with the TAC.
