VPN & PAT
mhcnetadmin
Hi all
I configured PAT rule so that the vpn traffic from a remote client is forwarded through cisco 2821 router to vpn box (Nortel contivity) the problem is that when IKE traffic received the router forwarded to the client but somehow missing I mean that the vpn box waits to ISAKMP proposal to come but nothing arrives, and the connection is terminated. Here are the rules
ip nat inside source static udp vpn_box_address 500 interface wan_interface 500 ( this is for IKE)
ip nat inside source static esp vpn_box_address interface wan_interface
I have configured access list to allow the traffic
Any idea?
smitty6504
Add GRE and AHP for your PAT and that should take care of it.
ok thanks i will try it on Sunday
you mean to the access list, because in PAT rules all I can add is esp,tcp,udp nothing else !!
the problem is solved the routing in the vpn box was wrong, thanks
