- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-06-2020 08:35 AM
Dear all,
I'm writing regarding a problem I'm facing with a brand new ISR 4451-X/K9 router .
I desperately need to reset the router to factory default configuration. The problem is, I can't break the boot sequence properly, and everytime I try, it proposes me to reset to factory default configuration I type 'y' and then it's resetting again and again (infinite loop)
Here is an exemple of the loop I'm facing :
Initializing Hardware ... Checking for PCIe device presence...done System integrity status: 0x610 Rom image verified correctly System Bootstrap, Version 16.7(4r), RELEASE SOFTWARE Copyright (c) 1994-2017 by cisco Systems, Inc. Current image running: Boot ROM0 Last reset cause: LocalSoft ISR4451-X/K9 platform with 16777216 Kbytes of main memory PASSWORD RECOVERY FUNCTIONALITY IS DISABLED ........ no valid BOOT image found Final autoboot attempt from default boot device... Failed to find bootable image on device bootflash: ... PASSWORD RECOVERY IS DISABLED. Do you want to reset the router to the factory default configuration and proceed y/n [n]: y Router clearing configuration. Please wait for ROMMON prompt... autoboot: boot failed, restarting... Resetting ....... Initializing Hardware ...
As a reminder, I'm unable to access to the router config ( Console username/password needed and linked to an unreachable AAA server...)
I'm even doubting about sending the "break" sequence properly. So,
- Could you please tell the proper moment to send the break sequence ( Does it matter ? )
- Have you got an idea on how to fix this please ?
Thanks in advance,
Solved! Go to Solution.
- Labels:
ISR 4000 Series
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-06-2020 01:32 PM
Here's the answer to why the router keeps going into a boot-loop: Someone disabled password-recovery feature.
To make a long story short, contact Cisco TAC and organize an RMA.
NOTE: I've been against this feature being "enabled" by Cisco developers (CSCvo02389) because it will be abused/mis-used (like in this case).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-06-2020 08:43 AM - edited 01-06-2020 08:44 AM
here is the good steps to follow and recovery :
https://community.cisco.com/t5/routing/think-i-ve-bricked-an-isr-4331/m-p/3888622
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-06-2020 11:08 AM
Your device is failing to find an IOS-XE image to boot. I would try putting an image on a USB memory key and see if you can get it to boot from that.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-06-2020 01:25 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-06-2020 01:32 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-07-2020 12:49 AM
Hello everyone,
I agree with @Leo Laohoo not all commands or features are good.
disabling password recovery command should be limited to only special purposes images used by military or banks and it should not be available to everyone.
There is no sense in creating a lot of RMAs. Cisco should make this change.
Hope to help
Giuseppe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-10-2020 07:04 AM
Unfortunately, telnet port wasn't configured yet. So we organized an RMA.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-10-2020 02:01 PM
