VPN
Hamid Amir
Question
I have a Cisco 877 router which connects my network to the Internet using an ADSL line, static IP address and NAT; the IOS version is 15.
Everything is working ok, but I'd like to configure this router to be a VPN server, to be able to connect to the network from the outside.
letting single remote computers access the internal network
I can connect  to my vpn from home using router ip as server name in vpn client (is this wright) but I can not from the outside using public internet
And, finally: how to set up this?
my config
Current configuration : 5563 bytes
! Last configuration change at 15:16:15 UTC Mon Aug 28 2017 by me
version 15.3
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
aaa new-model
aaa authentication login default local
aaa authentication login vpn_xauth_ml_1 local
aaa authentication login sslvpn local
--More--
*Aug 28 15:18:19.652: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access3, changed state to down
*Aug 28 15:18:19.660: %LINK-3-UPDOWN: Interface Virtual-Access3, changed staaaa authorization exec default local
aaa authorization network vpn_group_ml_1 local
aaa session-id common
memory-size iomem 10
crypto pki trustpoint TP-self-signed-4137654229
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4137654229
revocation-check none
rsakeypair TP-self-signed-4137654229
no ip dhcp use class
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.0 192.168.1.99
ip dhcp pool vlan1
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 90.207.238.97 90.207.238.99
ip domain name yourdomain.com
ip cef
no ipv6 cef
license udi pid C887VA-K9 sn FCZ1843C42Y
license boot module c800 level advipservices
vtp domain SKYBB
vtp mode transparent
username me privilege 15 secret 5 $1$9BoE$Zz74ymPxsv0oQu/5NTfdj.
username she secret 5 $1$HjSK$puFAwr96lu1Pdmdzt/4tB.
controller VDSL 0
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
encr 3des
hash md5
group 2
crypto isakmp client configuration group CCLIENTvpn
key firewallvpn
dns 10.0.0.10
pool VPN-Pool
acl vpn_resources
max-users 5
crypto isakmp profile vpn-ike-profile-1
match identity group CCLIENTvpn
client authentication list vpn_xauth_ml_1
isakmp authorization list vpn_group_ml_1
client configuration address respond
virtual-template 2
crypto isakmp profile VPN-Profile-1-ike-profile-1
match identity group group2
match identity group group1
virtual-template 2
crypto ipsec transform-set encrypt-method-1 esp-3des esp-sha-hmac
mode tunnel
crypto ipsec profile VPN-Profile-1
set transform-set encrypt-method-1
set isakmp-profile VPN-Profile-1-ike-profile-1
interface ATM0
no ip address
ip policy route-map voip
atm vc-per-vp 64
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Virtual-Template2 type tunnel
ip unnumbered Dialer0
tunnel mode ipsec ipv4
tunnel protection ipsec profile VPN-Profile-1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname 8059afb35580@skydsl
ppp chap password 0 df59b51e
ppp pap sent-username 8059afb35580@skydsl password 0 efrtyuie
ppp ipcp dns request
no cdp enable
ip local pool VPN-Pool 192.168.0.20 192.168.0.25
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list any interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended any
permit ip any any
ip access-list extended vpn_resources
permit ip 192.168.0.0 0.0.0.255 any
no cdp run
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
49 Replies 49
Hamid,
how exactly are you trying to connect, what client do you use (AnyConnect) ? What error or other message do you get ?
Hi George
I use cisco Client VPN and Anyconnect.
When I use Client on my mobile  I get error message the vpn server did not respond
when I use Anyconnect on my mobile I get error message could not connect to server. please verify connectivity and server adress .
When I use Anyconnect on my pc i get error message  No valid certificates available for authentication. 21:53:06 Connection attempt has failed.
Kind Regards
Hamid
the problem might be on the client side. Do the logs on the router show anything ?
Which AnyConnect version are you running ?
Can you run debug crypto ike and crypto ipsec on your router and Can you install DART and try to connect, then launch DART and send us the log zip file please
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Please see the attachement file as requested.
I couldnt find DART to install it.
for some reason, your VPN client expects a different encryption algorithm and no preshared authentication.
Try to change your policy to:
encr aes
hash md5
group 2
Sorry did no work.
best Regards
try and locate and then delete the AnyConnect client profile (in Windows it should be located in %ProgramData%\Cisco\Cisco AnyConnect Secure Mobility Client\Profile)...
I could'nt find the AnyConnect client profile in windows 10.
I found cisco client profile which I can connect to vpn from inside as I mentioned before. However when I use pc AnyConnect client there is no debug message only when I use my iphone I get a debug message.
in Windows 10, the 'Program Data' folder is hidden by default. You need to un-hide the files & folders in 'File Explorer' for it to become visible.
You can then go to C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client\Profile and check for any .pcf or .xml files...
I have program file i did search and show hidden. I could'nt find it
I found it and deleted but still same problem.
which AnyConnect client version are you using ?
Version 4.3
I could'nt find the AnyConnect client profile in Windows 10.
I have found the Cisco client profile which i can connect to vpn from inside as I mentioned before but not from outside however when I use the pc
AnyConnect client no debug message only when i use iphone  AnyConnect client .
Best Regards
