08-28-2017 10:19 AM - edited 03-05-2019 09:03 AM
I have a Cisco 877 router which connects my network to the Internet using an ADSL line, static IP address and NAT; the IOS version is 15.
Everything is working ok, but I'd like to configure this router to be a VPN server, to be able to connect to the network from the outside.
letting single remote computers access the internal network
I can connect to my vpn from home using router ip as server name in vpn client (is this wright) but I can not from the outside using public internet
And, finally: how to set up this?
my config
Current configuration : 5563 bytes
! Last configuration change at 15:16:15 UTC Mon Aug 28 2017 by me
version 15.3
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
aaa new-model
aaa authentication login default local
aaa authentication login vpn_xauth_ml_1 local
aaa authentication login sslvpn local
--More--
*Aug 28 15:18:19.652: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access3, changed state to down
*Aug 28 15:18:19.660: %LINK-3-UPDOWN: Interface Virtual-Access3, changed staaaa authorization exec default local
aaa authorization network vpn_group_ml_1 local
aaa session-id common
memory-size iomem 10
crypto pki trustpoint TP-self-signed-4137654229
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4137654229
revocation-check none
rsakeypair TP-self-signed-4137654229
no ip dhcp use class
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.0 192.168.1.99
ip dhcp pool vlan1
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 90.207.238.97 90.207.238.99
ip domain name yourdomain.com
ip cef
no ipv6 cef
license udi pid C887VA-K9 sn FCZ1843C42Y
license boot module c800 level advipservices
vtp domain SKYBB
vtp mode transparent
username me privilege 15 secret 5 $1$9BoE$Zz74ymPxsv0oQu/5NTfdj.
username she secret 5 $1$HjSK$puFAwr96lu1Pdmdzt/4tB.
controller VDSL 0
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
encr 3des
hash md5
group 2
crypto isakmp client configuration group CCLIENTvpn
key firewallvpn
dns 10.0.0.10
pool VPN-Pool
acl vpn_resources
max-users 5
crypto isakmp profile vpn-ike-profile-1
match identity group CCLIENTvpn
client authentication list vpn_xauth_ml_1
isakmp authorization list vpn_group_ml_1
client configuration address respond
virtual-template 2
crypto isakmp profile VPN-Profile-1-ike-profile-1
match identity group group2
match identity group group1
virtual-template 2
crypto ipsec transform-set encrypt-method-1 esp-3des esp-sha-hmac
mode tunnel
crypto ipsec profile VPN-Profile-1
set transform-set encrypt-method-1
set isakmp-profile VPN-Profile-1-ike-profile-1
interface ATM0
no ip address
ip policy route-map voip
atm vc-per-vp 64
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Virtual-Template2 type tunnel
ip unnumbered Dialer0
tunnel mode ipsec ipv4
tunnel protection ipsec profile VPN-Profile-1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname 8059afb35580@skydsl
ppp chap password 0 df59b51e
ppp pap sent-username 8059afb35580@skydsl password 0 efrtyuie
ppp ipcp dns request
no cdp enable
ip local pool VPN-Pool 192.168.0.20 192.168.0.25
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list any interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended any
permit ip any any
ip access-list extended vpn_resources
permit ip 192.168.0.0 0.0.0.255 any
no cdp run
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
09-01-2017 01:13 PM
there is another detai in your configuration that warrants a question: do you have an existing DNS server with IP address 10.0.0.10 on your network ?
Also, try and change the key to something different like 'cisco':
crypto isakmp client configuration group CCLIENT-VPN
key cisco
dns 10.0.0.10 ?
09-01-2017 01:15 PM
No!
09-01-2017 03:53 PM
09-02-2017 02:27 AM
I am using cisco client VPN and I concifigured windows VPN Client to remote access
as well.
Hamid
09-02-2017 05:57 AM
09-02-2017 07:05 AM
09-02-2017 07:32 AM
what is the output of:
show crypto key mypubkey rsa TP-self-signed-4137654229
That said, WEBVPN might be another option (I think that is what Francisco is referring to), I'll send the configs.
Can you post the output of ;show version' ?
09-02-2017 07:44 AM
09-02-2017 07:45 AM
When you connect using Cisco VPN client, did it connect and not and to reach internal resources or it doesn't connect.
I see there tunnel coming up and also they exchange dpd....
While connected with vpn client, can you share output of show crypto isakmp sa and show crypto ipsec sa?
For anyconnect, i want taking essentially for webvpn, but also for ipsec. You can use anyconnect for pure ipsec as soon as you use ikev2 and not ikev1.
My confusion was that there were discussions based on anyconnect 4.3 and this logs is for legacy vpn client 5.
09-02-2017 08:18 AM
AS I mentioned I am trying to use both Cisco VPN client and Anyconnect to connect from outside..
I can connect using Cisco VPN client from home but I cannot establish connection from outside.
So the issues I cannot connect from outside (when I use public internet for example).
Please see the attachment as requested.
09-02-2017 10:00 AM
Hamid,
stupid question maybe, but how do you connect from the outside ? Dialer0 has ip address negotiated, make sure you use the IP address assigned to Dialer0 to connect...
09-02-2017 10:27 AM
It is cleaver question. I am not professional in cisco VPN.
I use to have static ip address from internet provider but know I have dynamic ip address.
I did use router ip address as server as input in cisco vpn client as I mentioned in my first question.
So how to assigned IP address to Dialer0. may be use dyn.com?
09-02-2017 10:37 AM
show ip int brief
should show you the IP address assigned by your ISP to the dialer interface. That is the address you need...
09-02-2017 11:28 AM
Yes it is working now with Dial0 ip address on my iPhone!!!
I hope my final stupid question. DO I need to register
with DynDNS.com for my static ip address?
Thanks you and Francesco for your help and patience with stupid old man.
DynDNS.com
09-02-2017 11:44 AM
DDNS is definitely a good idea, since 'ip address negotiated' means that the IP address can change. DynDNS is free as far as I know...
Glad that you got it working, let us know if you are running into any other issues...
