VRF Lite and NAT
vlacmanov
Dear All,
I have problem with VRF Lite and NAT on IOS
I tried two configuration without success
! ### Config 1
version 15.5
interface GigabitEthernet0/0
 ip vrf forwarding EXTERNAL
 ip address 8.1.61.118 255.255.255.248
 ip nat enable
interface GigabitEthernet0/1
 ip address 2.1.155.50 255.255.255.240
 ip nat enable
ip nat source static 2.1.155.61 8.1.61.116 vrf EXTERNAL
! ### Config 2
version 15.5
 ip nat outside
 ip nat inside
ip nat inside source static 2.1.155.61 8.1.61.116 vrf EXTERNAL
! when I remove VRFs everything is working fine
Kind regards,
Vice Lacmanovic
vlacmanov
I also tried
ip nat inside source static 2.1.155.61 8.1.61.116 vrf EXTERNAL extendable match-in-vrf
Kind regards,
Vice Lacmanovic
I think that vrf require the "ip nat enable" commando, not ip nat inside|outside
Bye,
enrico
PS: please rate if useful
milan.kulik
Level 10
Level 10
what exactly did not work?
How did you test (trace/capture packets)?
Was routing for the VRF configured correctly?
Milan
