VRF Lite
jahilnt10
I'm just testing this out. I have configured two VRF instance. And I'm exporting and importing vrf table from Cust-A to vice versa.
ip vrf Cust-A
rd 1:1
route-target export 1:1
route-target import 1:1
route-target import 2:2
ip vrf Cust-B
rd 2:2
route-target export 2:2
interface FastEthernet0/1/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
load-interval 30
full-duplex
no cdp enable
interface FastEthernet0/1/0.1
encapsulation dot1Q 99
ip vrf forwarding Cust-A
ip address 10.192.168.1 255.255.255.0
no cdp enable
interface FastEthernet0/1/0.2
encapsulation dot1Q 169
ip vrf forwarding Cust-B
ip address 10.192.169.1 255.255.255.0
no cdp enable
If I do show ip route vrf Cust-A or Cust-B ..
show ip route vrf Cust-B
10.0.0.0/24 is subnetted, 1 subnets
C 10.192.169.0 is directly connected, FastEthernet0/1/0.2
Routing Table: Cust-A
C 10.192.168.0 is directly connected, FastEthernet0/1/0.1
If i'm importing and exporting route target from both VRf than both VRF should exchange routing table and I must see Cust-A routes in Cust-B VRF table and vice versa..
what i'm doing wrong here...
Second, what if i want my Cust-B users to access internet while internet default route is in global table?
royalblues
Level 10
Level 10
I think you would require BGP to import the routes eventhough you do not run MPLS or peer with anyone in VRF lite
Can you add the following and let us know how it goes
router bgp 65530
no synchronization
bgp log-neighbor-changes
no auto-summary
address-family ipv4 vrf Cust-A
redistribute connected
no synchronization
exit-address-family
address-family ipv4 vrf Cust-B
no synchronization
exit-address-family
Narayan
