vrf
eng_adel273
I attach GnS3 files & configuration for vrf for two customer
MY problem
- on PE1  ,  I can't execute          ping vrf customer_1 10.0.2.9
- on PE2  ,  I can't execute         ping vrf customer_1 10.0.1.9
27 Replies 27
I follow your advise but still not working , show bgp vpnv4 unicat , it shown the PEs without probelm
are the configs of R6, R7, R8 and R9 already posted here somewhere ? With the five configurations you posted, I can ping end to end, so the problem must be with the CE routers...
I can't ping from  R4 this commnd
ping vrf customer_1 10.0.2.9 source 172.16.1.9
aslo
in CEs , I configured only the interfaces and static route for their PE
On the CE's you should have OSPF, because that is the protocolo redistributed into the PE. Could you please share the CE config? Im going to provide you the config you should have for Customer 1
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
I attached required file for all CEs
Thank you
You must replace the static route by OSPF because you are using OSPF on the PE's and making mutual redistribution between OSPF and BGP.
Example:
CE
interface g0/0
ip address 10.0.0.2 255.255.255.252
no shutdown
router ospf 1
network 0.0.0.0 255.255.255.255 area 0
PE
ip vrf CUSTOMER1
rd 1:1
route-target import 1:1
route-target export 1:1
interface loopback 0
ip add x.x.x.x 255.255.255.255
int g0/0
ip vrf forwarding CUSTOMER1
ip add 10.0.0.1 255.255.255.252
no shutdown
router ospf 100
mpls ldp auto
network <local loopback>
network <local networks used into the ISP infrastructure>
router ospf 1 vrf CUSTOMER1
network 10.0.0.1 0.0.0.0 area 0
redistribute BGP 100 subnet
router bgp 100
--- omitting VPN config ---
address-family ipv4 vrf CUSTOMER1
redistribute OSPF 1
I have not followed the entire thread, but try and give the loopback interfaces on R4 and R5 a /32 mask.
This is the only change I made to your original configuration, with the result being:
R4#ping vrf customer_1 10.0.2.9
Sending 5, 100-byte ICMP Echos to 10.0.2.9, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 136/184/224 ms
R5#ping vrf customer_1 10.0.1.9
Sending 5, 100-byte ICMP Echos to 10.0.1.9, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 108/142/196 ms
R4
interface Loopback1
ip address 100.0.0.5 255.255.255.255
ip ospf 1 area 0
R5
interface Loopback1
ip address 100.0.0.6 255.255.255.255
ip ospf 1 area 0
Thank your for your help
Sorry for late reply .
I applied your advise but some time the ping result was !!!!! , ..!!! , .!!.. , .....
what does this means.
Could you please share the configuration including the changes?
Thank you in advance.
R4
interface Loopback1
ip ospf 1 area 0
R5
interface Loopback1
ip ospf 1 area 0
Thank you, the complete configuration please :-)
Already Attached  , please check it
kindly find the configuration lab
https://www.mediafire.com/folder/9fyf7cnfhe3ni/lab3
