VS-S720-10G-3C
Sherdilkhan2015
My VS-card is keep crashing the IOS after using all the latest versions and older versions as well, can anyone suggest what i need to do? it is going till downloading mode when i press no for configuration. THEN AFTER THAT IT IS KEEP RESTARTING AND GOING TO ROMMON MODE.
pLEASE HELP ME WITH THIS.
6 Replies 6
Leo Laohoo
Post the complete output to the following commands:
  • sh version;
  • sh sup-bootflash:
  • sh log
Thanks for reply back but the problem is it is not allowing me take show version as when i am trying to write enable command it is going to restart and crash that card again coming on rommon mode.
Ok, post the entire boot and crash process.  We want to see where it's failing.
this is what i am getting sir
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]: n
Press RETURN to get started!
00:01:33: % Error opening nvram:/ifIndex-table No such file or directory
00:01:35: curr is 0x0
00:01:35: RP: Currently running ROMMON from S (Gold) region
00:01:45: %SYS-5-RESTART: System restarted --
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Versio
n 12.2(33)SXH2a, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 25-Apr-08 08:07 by prod_rel_team
00:00:09: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure con
sole debugging output.
00:01:32: SP: SP: Currently running ROMMON from S (Gold) region
00:01:45: %SYS-SP-5-RESTART: System restarted --
Cisco IOS Software, s72033_sp Software (s72033_sp-ADVIPSERVICESK9_WAN-M), Versio
Compiled Fri 25-Apr-08 08:20 by prod_rel_team
00:01:45: %DOSFS-SP-5-DIBERR: disk0 is formatted from a different router or PC.
A format in this router is required before an image can be booted from this devi
ce
00:01:45: %SYS-SP-6-BOOTTIME: Time taken to reboot after reload = 62041 seconds
00:01:46: %OIR-SP-6-INSPS: Power supply inserted in slot 1
00:01:46: %C6KPWR-SP-4-PSOK: power supply 1 turned on.
00:01:46: %OIR-SP-6-INSPS: Power supply inserted in slot 2
00:01:46: %C6KPWR-SP-4-PSOK: power supply 2 turned on.
00:01:46: %C6KPWR-SP-4-PSREDUNDANTBOTHSUPPLY: in power-redundancy mode, system i
s operating on both power supplies.
00:01:49: %C6KENV-SP-4-FANHPMODE: Fan-tray 1 is operating in high power mode
00:01:54: %FABRIC-SP-5-CLEAR_BLOCK: Clear block option is off for the fabric in
slot 6.
00:01:54: %FABRIC-SP-5-FABRIC_MODULE_ACTIVE: The Switch Fabric Module in slot 6
became active.
Router>
Router>
Router>
Router>
%Software-forced reload
17:40:11 UTC Sun Jan 2 2000: Breakpoint exception, CPU signal 23, PC = 0x425F82
D0
Possible software fault. Upon reccurence, please collect
crashinfo, "show tech" and contact Cisco Technical Support.
-Traceback= 425F82D0 425F5E8C 42335714 42335740 421C3A10 4220E678 4220E6D4 40845
35C 40845DDC 422C55B0 422C184C 422C1A68 425EB30C
$0 : 00000000, AT : 43B40000, v0 : 456C0000, v1 : 44570000
a0 : 50B40B70, a1 : 0000F100, a2 : 00000000, a3 : 00000000
t0 : 425EB928, t1 : 3400F101, t2 : 425EB938, t3 : FFFF00FF
t4 : 425EB928, t5 : 00002E32, t6 : 40000000, t7 : 00000000
s0 : 00000000, s1 : 43B10000, s2 : 46982F78, s3 : 0000001F
s4 : 00000040, s5 : 46982F78, s6 : 44B60000, s7 : 00000000
t8 : 5000DBBC, t9 : 00000004, k0 : 00000000, k1 : 00000000
gp : 43B49090, sp : 5000DC68, s8 : 00000000, ra : 425F5E8C
EPC : 425F82D0, ErrorEPC : 81080004, SREG : 3400F103
MDLO : 00000000, MDHI : 00000000, BadVaddr : 00000000
DATA_START : 0x4378F090
Cause 00000024 (Code 0x9): Breakpoint exception
Writing crashinfo to bootflash:crashinfo_20000102-174011
=== Flushing messages (17:40:11 UTC Sun Jan 2 2000) ===
Buffered messages:
ce
slot 6.
became active.
Queued messages:
00:02:00: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging out
put.
00:01:58: %CPU_MONITOR-3-PEER_EXCEPTION: CPU_MONITOR peer has failed due to exce
ption , reset by [6/0]
*** System received a Software forced crash ***
signal= 0x17, code= 0x24, context= 0x456b9d34
PC = 0x425eb984, SP = 0x43b0de58, RA = 0x4114d5dc
Cause Reg = 0x00003820, Status Reg = 0x34008002
rommon 1 > en
monitor: command "en" not found
rommon 2 >
rommon 2 >
Upgrade the IOS.  SXH is a pretty old, old train.
Can you confirm IOS please ?
