VS-SUP2T-10G card with WS-X6748-GE-TX Card message DFC Problems
frites
Hello ,
i try to  add a line card WS-X6748-GE-TX to cisco C6509E  with Suprvisor VS-SUP2T-10G
the line card not reconize by the switch  , no status and a message :
: %C6KENV-2-DFCMISMATCH: Module 9 DFC incompatible with Supervisor DFC.  Power denied
the cli   show  module power
Mod Card Type Admin Status Oper Status
1 CEF720 24 port 1000mb SFP on on
5 Supervisor Engine 2T 10GE w/ CTS (Acti on on
6 Supervisor Engine 2T 10GE w/ CTS (Hot) on on
9 CEF720 48 port 10/100/1000mb Ethernet on off (DFC mismatch)
the cli show module :
SW-6509E#sh module
Mod Ports Card Type Model Serial No.
1 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAL1408BLHC
5 5 Supervisor Engine 2T 10GE w/ CTS (Acti VS-SUP2T-10G SAL2102068E
6 5 Supervisor Engine 2T 10GE w/ CTS (Hot) VS-SUP2T-10G SAL210400PD
9 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL124378LG
Mod MAC addresses Hw Fw Sw Status
1 68ef.bd08.f288 to 68ef.bd08.f29f 4.3 12.2(18r)S1 15.1(1)SY5 Ok
5 006b.f11a.cba0 to 006b.f11a.cba7 2.1 12.2(50r)SYS 15.1(1)SY5 Ok
6 006b.f11a.ccdf to 006b.f11a.cce6 2.1 12.2(50r)SYS 15.1(1)SY5 Ok
9 0023.5e7f.b7b8 to 0023.5e7f.b7e7 3.0 Unknown Unknown PwrDown
Mod Sub-Module Model Serial Hw Status
1 Centralized Forwarding Card WS-F6700-CFC SAL1408BTZH 4.1 Ok
5 Policy Feature Card 4 VS-F6K-PFC4XL SAL2048020K 3.0 Ok
5 CPU Daughterboard VS-F6K-MSFC5 SAL20450329 3.1 Ok
6 Policy Feature Card 4 VS-F6K-PFC4XL SAL2048021V 3.0 Ok
6 CPU Daughterboard VS-F6K-MSFC5 SAL210306P8 3.1 Ok
9 Distributed Forwarding Card WS-F6700-DFC3BXL SAL12437JT7 5.3 PwrDown
Mod Online Diag Status
1 Pass
5 Pass
6 Pass
9 Not Applicable
what i can do to solve this problem
Leo Laohoo
Slot 9 has an incompatible DFC3B card.
balaji.bandi
I have seen this issue - when we migrating from OLD cards to Sup2T based Cat 6K, the Module has some daughter boards which was not supported.
I had othe card which support, which i repalce with that it was worked. (may be not your case, so get the Moduile - which support)
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/107258-C6K-PFC-DFC-CFC.html
BB
Giuseppe Larosa
Hello @frites ,
You would need a DFC4 to put in place of the current daughter card if compatible with the linecard otherwise a CFC like the one you have in slot 1:
Hope to help
Giuseppe
hello ,
thx for your replay , i tray to buy a daughter  card WS-F6700-CFC
