Deleting ACL
yee.lay.yo
Hi All,
How can I remove single ACL line from my ACL list?
8 Replies 8
Edison Ortiz
Let's take this ACL as an example:
R2#sh ip access-lists
Extended IP access list 101
10 permit ip host 1.1.1.1 host 2.2.2.2
20 permit ip host 1.1.1.1 host 3.3.3.3
30 permit ip host 1.1.1.1 host 4.4.4.4
You noticed how the output has a number from 10 to 30 on each ACE?
Now, let's say I want to knock out line number 20.
R2(config)#ip access-list extended 101
R2(config-ext-nacl)#no 20 permit ip host 1.1.1.1 host 3.3.3.3
R2(config-ext-nacl)#end
HTH,
__
Edison.
Please rate helpful posts
Edison,
That's pretty handy - I didn't know you could edit a numbered ACL as if it was a named ACL.
Hi Edison,
That's a great post. One of the most succinct I've seen.
Gilbert
Marwan ALshawi
When you edit an ACL, it requires special attention. For example, if you intend to delete a specific line from a numbered ACL that exists as shown here, the entire ACL is deleted
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00800a5b9a.shtml#editacls
Rate if helpful
Also, i believe you need at least version 12.3 of the IOS in order to delete numbered access-lists line by line
just tested on 65k with 12.2 - all good. I suspect this method has been available for longtime, it's just been hidden (not to be confused with 'hidden' commands).
Ajaz
yee.lay.yo
Hi Edison,
The problem fix by your instruction.
Thanks a lot.
Hello
Just like to add you should be able to do this even with standard numbered acls and also be able to just to specify the ace number when deleting or adding an ace
Example1:
access-list 10 permit 10.10.10.0
access-list 10 permit 20.10.10.0
sh access-lists
Standard IP access list 10
20 permit 20.10.10.0
ip access-list standard 10
no 20
20 permit  20.20.20.0
Example2:
access-list 101 permit ip 10.10.10.0 0.0.0.255 any
access-list 101 permit ip 20.10.10.0 0.0.0.255 any
sh access-lists
10 permit ip 10.10.10.0 0.0.0.255 any
20 permit ip 20.10.10.0 0.0.0.255 any
no 20
20 permit  ip 20.20.20.0 0.0.0.255 any
Kind Regards
Paul
