Vulnerability assesment Tool
saquib.tandel
Hello All
Seeking for suggestion on vulnerability assesment Tool for Router and Switches. Appreciate kind input
cheers
Saquib
sean_evershed
Level 7
Level 7
IOS has a built in auto secure feature. See below
http://blog.ipexpert.com/2011/04/25/ciscos-autosecure/
See also this list of tools. One of my favorites is Nipper.
http://packetlife.net/armory/category/vulnerability-scanning/
You can also copy your config into the Output Interpreter for an analysis
https://www.cisco.com/cgi-bin/Support/OutputInterpreter/home.pl
Don't forget to rate posts that are helpful.
Cheers
Sean
sean_evershed
Level 7
Level 7
Cheers
Sean
Thank You Sean
I would recommend to look at Nessus or NeXpose Vulnerability assesment/managment tools.
Audrius
