VXLAN and RSPAN between branches
dijix1990
I have vxlan between two branches (configured on the asr1002-x) and I wanted to configure rspan between these branches. Can RSPAN vlan work through vxlan configuraton?
16 Replies 16
Torbjørn
Hello @dijix1990,
The best tool for the job would be Encapsulated Remote SPAN(ERSPAN). This encapsulates the span traffic in GRE and allows you to route it to where you need it.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
I need to span phones traffic from vlan voice to vlan rspan. Record server only one
What kind of recording server are you using? Most of the current ones use a SIP trunk and recording profile instead of a SPAN port.
I need to record sessions between two phones which placed on the same switch
You could set up RSPAN on your 2960 and use the RSPAN VLAN as source VLAN for ERSPAN on your gateway device - that is assuming that the two phones are on the same site and your recording server is remote.
don't understand your idea.
OK, I have 2960 with monitor session
monitor session 1 source vlan 975
monitor session 1 destination remote vlan 103
what I need to do to encapsulate rspan to erspan on my asr1002-X
On your ASR you configure VLAN 103 as source. Refer to the following config guide for detailed instructions: https://www.cisco.com/c/en/us/td/docs/routers/ios/config/17-x/lan-wan/b-lan-wan/m_lnsw-conf-erspan.html
Your source ERSPAN configuration would look something like this:
monitor session 100 type erspan-source
    source vlan 103
But asr1002x it's l3 device. It doesn't have l2 ports, there's only bdi for l2 features
That is fine. You can use an L3 interface/subinterface as a source.
And how? Vlan 103 is l2 only  how can I sent traffic of rspan via asr? I use erspan, but only for traffic L3 and I don't know how can I sent vlan 103 without gateway through erspan
M02@rt37
Hello @dijix1990
RSPAN ? VXLAN replaces traditional VLAN-based forwarding, and RSPAN relies on VLANs to transport mirrored traffic...
ERSPAN should be a solution since it mirros trafic over L3 network
Other way, if you really want to mirror traffic into a vlan and rely on VxLAN to carry it across sites you should create a VxLAN VNI mapped to the same VLAN as the SPAN target VLAN. Mirror traffic into that VLAN locally and ensute that VLAN is bridged acriss sites via VxLAN
Best regards
Hm can you give an example of create a VxLAN VNI mapped to the same VLAN?
I tried to use this construction for RSPAN
bridge-domain 103
 member vni 6025
 member GigabitEthernet0/0/1 service-instance 103
bridge-domain 975
 member vni 6035
 member GigabitEthernet0/0/1 service-instance 975
interface GigabitEthernet0/0/1
 service instance 103 ethernet
  description RSPAN
  encapsulation dot1q 103
   service instance 975 ethernet
  description Voice_DHCP
  encapsulation dot1q 975
Branch 1 - VXLAN - Branch 2
Branch 1 has record server and rspan configuration
the same Branch 2 has rspan configuration
but after it I see macflap
May 14 12:03:54.491: %SW_MATM-4-MACFLAP_NOTIF: Host 0077.8df9.b2b0 in vlan 103 is flapping between port Twe1/0/45 and port Po19
May 14 12:03:54.491: %SW_MATM-4-MACFLAP_NOTIF: Host b4a8.b9e8.5fe8 in vlan 103 is flapping between port Po19 and port Po28
Apparently, the mac addresses from site 1 that are packed into vlan103 after vxlan are unpacked for some reason
sh mac add vlan 103
          Mac Address Table
Vlan    Mac Address       Type        Ports
 103    0004.a3b9.67f0    DYNAMIC     Twe1/0/45
 103    0004.f2f2.3a6c    DYNAMIC     Twe1/0/45
 103    0004.f2f7.ca1e    DYNAMIC     Twe1/0/45
 103    001b.d432.e7c9    DYNAMIC     Twe1/0/45
Thanks for that output @dijix1990
As discussed, RSPAN is not VxLAN-aware. So it causes MAC learning of mirrored (spoofed) trafic, which leads to flapping.
So, use ERSPAN, which avoids flooding and MAC learning issues beacuse it encapsulates mirrored trafic in GRE/IP, as @Torbjørn proposed.
Best regards
