WAN Configuration and Set-up
paulgrg22
My ISP give me a public ip address subnetmask, DNS and a MODEM now, i have my cisco 1750 router and i want to used it can anybody here give an idea on should i do this using my router how can i coonect it to my modem...any help pls i need to used my router and i need ur help out there..thanks
8 Replies 8
Edison Ortiz
What kind of WAN service is this ? (DSL, T1, Cable, etc)
Is the 1750 router used for anything else at the moment or this is new ?
the WAN service is DSL..the 1750 router is used before...and i know the password but i didn't know how to configure it any help please!!!
Paul
dschuckman
Paul,
I am going to give you a basic configuration based on the information that I see here. I am assuming that your ISP provided a external modem with ethernet capability.
On the 1750 router connect one interface to the modem.
On this interface, do the following
router#configure terminal
router(config)#int X
router(config-if)#ip address X.X.X.X 255.255.X.X
router(config-if)#no shut
configure your gateway of last resort
router(config)#ip route 0.0.0.0 0.0.0.0 [gateway]
configure your name servers
router(config)#ip name-server [dns server]
doing the above configuration should get connected to the internet from the router.
Now I am going to assume you want to use privates addresses and nat for the connecting devices behind the router.
So on interface y
router(config)#int y
router(config-if)#ip address 192.168.10.1 255.255.255.0
router(config-if)# ip nat inside
go back to interface X
router(config)#int x
router(config-if)# ip nat outside
Then configure the nat
router(config)#ip nat inside source list 10 interface X overload
router(config)#access-list 10 permit 192.168.1.0 0.0.0.255
This should get you basic connectivity.
router(config-if)#ip address X.X.X.X 255.255.X.X(Is this My public IP that ISP give n?)
router(config)#ip route 0.0.0.0 0.0.0.0 [gateway](The gateway of my ISP That they give?)
router(config)#ip name-server [dns server](My ISP give me two DNS how could i used it)
So on interface y
router(config-if)#ip address 192.168.10.1 255.255.255.0(is this my private IP and subnetmask?)
to connect router and modem i used straight thru cable and using the AUX port of my router is this correct???
i dont think so ..
if u have a DSL internet from the ISP u must have got an ADSL modem. connect your modem to your router's fastEthernet interface using a Cross cable (thats what we are using).
hope this helps..
Hi..
How about if I share my internet in a Local Area Network what should I do which port in the router that I used because the fast ethernet port is used to connect my modem so the vacant port in router are the console port and the AUX port...
We use the 1750s with a WIC card installed. We use the WIC port for WAN and the built in fast eithernet port for our LAN.
You will need to purchase a wic1enet card.
