wan connection
dave dave
hi! We are currently looking into subscribing IP VPN connection between our 2 branch offices to the main site. I was told by the telco that they will be providing the router and that single link at each site can be use to establish wan connection between sites and internet.
I'm very new to this, i was told that an Cisco ASA is required for this setup. Let me know how this can be done and the guideline on the configuration on the router and ASA + how;s the physicall connection like?....A simple config will be helpful. Thanks.
paolo bevilacqua
You can do that with routers also. The router also support more features and are easier to configure and troublehoot.
In either case, hire a consulant for the job, as if you try youself it can be very confusing stuff.
any pointer or basic steps that i can go through if i would to do the setup myself? the main objective is to establish the site to site wan link and segregate some bandwidth for internet. Thanks.
