WAN ethernet port configuration?????
CHN
i have a 3-layer switch 3560 to instead a old router.
because 3560 doesn't have WAN port,I have to convert fiber cable to RJ-45.
what should i do?
need i to configurate on the port?
desai.jaideep
Level 5
Level 5
Are you saying that you will terminate a Fiber optic cable to the switch and your RJ-45(LAN) devices sho
uld be connected to it.
Can please give what will be the device connected to other end of FO.
JD
mmorris11
Level 4
Level 4
All 3560 switches have SFP ports which can accept a module that supports fiber. The part #s for the available modules to do this are at the bottom of this page:
http://www.cisco.com/en/US/customer/products/hw/switches/ps5528/products_data_sheet09186a00801f3d7d.html
pls rate if helpful.
