WAN problem
karamalomari
I have a problem with my Internet connection a the link is flapping up and down. Below is the configuration that i have on the router and the errors that i am getting:
Current configuration : 2589 bytes
version 12.4
service password-encryption
hostname RTR1
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ip cef
ip domain name yourdomain.com
vpdn enable
interface FastEthernet0/0
description **FROM_ASA**
ip address 10.x.x.x 255.255.255.248
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
description WAN Interface
no ip address
no ip unreachables
ip nat outside
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
interface Dialer1
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname iatadmn
ppp chap password 7 xxxxxx
ppp pap sent-username iatadmn password 7 xxxxx
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 10.0.0.0 255.0.0.0 10.7.221.5
ip http server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 10.0.0.0 0.255.255.255
access-list 101 permit ip 10.7.0.0 0.0.255.255 any
access-list 101 permit ip 10.8.0.0 0.0.255.255 any
control-plane
line con 0
logging synchronous
login local
line aux 0
line vty 0 4
privilege level 15
logging synchronous
login local
transport input telnet
line vty 5 15
privilege level 15
logging synchronous
login local
line vty 16 807
logging synchronous
login local
scheduler allocate 20000 1000
end
The errors are the following:
611: %DIALER-6-BIND: Interface Vi1 bound to profile Di1
*Aug 23 10:49:24.615: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to upterface Virtual-Access1, changed state to up
*Aug 23 07:47:22.763: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
*Aug 23 07:47:45.851: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Aug 23 07:48:48.939: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
.675: %LINK-3-UPDOWN: Interface Dialer1, changed state to up
Mohamed Sobair
Level 7
Level 7
You dont need natting outside on Fastethernet0/1 interface, you already have it on the Dialer Interface.
Check the link between your ADSl modem and Fastethernet0/1 , flapping here should result in flapping on the dialler as well.
Mohamed
There are two things I'd look at in your configuration.
I'd make sure the PPP negotiation and authentication is succeeding. I think this is the most likely cause of the flapping if it is not a physical interface problem.
Otherwise, it looks like you have a dialer-group statement under the Dialer1 interface that is not associated with a dialer-list. Perhaps you simply did not include the dialer-list statement in the posted config. The dialer-group causes the Dialer1 interface to come up only if there is interesting traffic, specified by an access list, which is associated with a dialer-list. The dialer-group/dialer-list combination is usually used in a Dial-on-demand situation. If that is not your intent, I'd remove the dialer-group statement.
