wan redundancy routing
network770
I have 2 sites and 2 wan providers interconnecting the two of them, so far I have all the traffic going over the wan1 and I would like like to dynamically route hte traffic to wan2 in case wan1 goes down.
I tried to create a second route with a higher cost but that doesn't seem to work.
So for example:
                          - 192.168.1.1 ------WAN1-------192.168.1.2 -
  1.1.1.0-->SITE1---                                                           ---SITE2<--2.2.2.0
                          -192.168.2.1 ------WAN2-------192.168.2.2 -
I have setup on site2:
ip route 1.1.1.0 255.255.255.0 192.168.1.1
ip route 1.1.1.0 255.255.255.0 192.168.2.1 100
(note that my default route on site 2 is 192.168.1.1 but that too i want to reroute through wan2 if wan2 goes down)
and on site1:
ip route 2.2.2.0 255.255.255.0 192.168.1.2
ip route 2.2.2.0 255.255.255.0 192.168.2.2 100
but when I remove the primary route on site2 the traffic does not get reouted to wan2
any idea why?
Also, would ip sla be a better option?
what is the easiest and least traffic impacting?
milan.kulik
Level 10
Level 10
what kind of WAN service are you buying from your providers?
It seems like L1/L2 only?
Wouln't be easier to run some dynamic routing protocol between your sites?
BR,
Milan
we control the ip schema on both, so it is our layer 3 devices facing the wan.
but how do we reroute traffic to the 2nd wan circuit if the first one fails?
is ipsla the answer?
tried creating another route with a different cost but that didn't work
Hi, Ronni.
My opinion is: if you have 2 service provider that represent recurrent cost (mensual), may be is necessary to use both. (This is only a personal opinion)
What bandwidth have every link?
the simple form to have redundancy is:
One primary route's and one secondary route's with worse administrative distance (floating route); with this if the primary route's fail then the second can enter on routing table.
It is so important know the kind of your WAN connection; because if for example its frame relay you need track de DLCI state, but according to the service type you can choose a type of configuration with multiples tools to go to your target.
This link can help you http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html; but I need more information to study the scenario.
I hope it help you
you
