WAN router LAN interface Best practice for speed
Steve Coady
Hello
I have an ASR router with a WAN link of 100M.
The LAN connection for this router is Gig capable.
Should I configure the LAN interface on the router for Gig or would this cause problems with potentially 10 times the data
exiting the LAN out to the WAN with only a 100M pipe?
sMc
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
If you set your LAN interface to run at 100Mbps, likely you would just be moving your possible bottleneck one hop deeper into your LAN (often on devices with weak QoS support).
Leave your LAN interface at gig.  If congestion, on WAN egress, becomes an issue, you can then try QoS to mitigate it.  For example, for starters, you might want to place your WAN egress traffic into fair-queue.
Joseph W. Doherty
Disclaimer
Posting
