WAN Router Problem
valiegenus
Dears ,
I have Faced the following message on router that keeps appearing till i restarted the router : %HWIC_HOST-1-RXCLK_MISSING_ERROR: HWIC_HOST: The HWIC Receive Clock signal was n
ot detected for Interface Descriptor Block 0x42ED6600
FastEthernet0/1/0: hwic_host_error_handler: Error Event Register = 0x20, IDB = 0
x42ED6600.
what is the reason of that .
7 Replies 7
paolo bevilacqua
Which exact IOS are you running ?
Model 2800 , Version 12.4(3d)
Can you upgrade to 12.4(3j) and check again.
williamsdo
Level 3
Level 3
Hi, your router may have a bug in the IOS, the closk signal was not detected on the interface. have a look at the Cisco error message decoder, yes you most likely looking at a IOS upgrade.
Select Software: All Supported Software
suggest related documents within results
Showing 1-1 of 1 results Page: 1
1. %HWIC_HOST-1-RXCLK_MISSING_ERROR: HWIC_HOST: The HWIC Receive Clock signal was not detected for Interface Descriptor Block [hex]
The host termination logic has encountered a fatal error. The logic could not detect the HWIC receive clock for the interface specified by the IDB. This condition indicates a software error.
Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/cgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://www.cisco.com/cgi-bin/front.x/case_tools/caseOpen.pl, or contact your Cisco technical support representative and provide the representative with the information you have gathered. Attach the following information to your case in nonzipped, plain-text (.txt) format: the output of the show logging and show tech-support commands and your pertinent troubleshooting logs.
Related documents- No specific documents apply to this error message.
Goutam Sanyal
Level 4
Level 4
As per Donald Williams's post please open a TAC case. The same also found at cisco site.
Goutam
I am experiencing the same problem:
%HWIC_HOST-1-RXCLK_MISSING_ERROR: HWIC_HOST: The HWIC Receive Clock signal was not detected for Interface Descriptor Block 0x4554B754 FIO ext. events 0x00000014
FastEthernet0/1/0: hwic_host_error_handler: Error Event Register = 0x20, IDB = 0x4554B754
On 2811 with HWIC-9ESW-POE card installed.
What was the IOS fix for this or am I having a H?W problem, because this router has been running for months with the same IOS version, which is
Musetha
MOst of the time i experience this issue is when the HWIC card is faulty caused by electrical shock or hit by the lightning...Most on the ADSL HWIC.
