WAN routing issues---need some help please!
dstriplin1
I'm trying to connect a basic comcast modem only (not modem/router combo) to my 2921 router and have it give internet access to my lab. Any help is greatly appreciated!
Here is my current setup and topology
Internet- assigned via dhcp from Comast
Network LAN 10.0.1.0/24
PC address - 10.0.1.22
GW- 10.0.1.1
Here are the outputs from sh run and show ip int
Lab2921#show run
Building configuration...
Current configuration : 2452 bytes
! Last configuration change at 15:06:44 UTC Tue Mar 26 2019
version 15.7
no parser cache
service timestamps debug uptime
service timestamps log uptime
hostname Lab2921
boot-start-marker
boot-end-marker
logging userinfo
enable secret 5 $1$aP02$GoblxTJ6F3.kaw7Soxvr50
no aaa new-model
ip dhcp excluded-address 10.0.1.1
ip dhcp excluded-address 10.0.1.2
ip dhcp excluded-address 10.0.1.177
ip dhcp excluded-address 10.0.1.169
ip dhcp excluded-address 10.0.1.100 10.0.1.254
ip dhcp excluded-address 10.0.1.1 10.0.1.5
ip dhcp pool InsideDHCP
import all
network 10.0.1.0 255.255.255.0
default-router 10.0.1.1
dns-server 8.8.8.8 8.8.4.4
class any
ip dhcp class any
no ip domain lookup
ip cef
no ipv6 cef
vty-async
license udi pid CISCO2921/K9 sn FTX1728AHR1
redundancy
no cdp run
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Facing the ISP (the WAN)
ip address dhcp
ip nat inside
ip virtual-reassembly in
no ip route-cache
duplex auto
speed auto
no cdp enable
bridge-group 59
bridge-group 59 spanning-disabled
interface GigabitEthernet0/1
description Facing my LAN (the LAN)
ip address 10.0.1.1 255.255.255.0
ip nat outside
no ip route-cache cef
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip default-gateway 10.0.1.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
access-list 1 permit 10.0.1.0 0.0.0.255
access-list 102 permit ip 10.0.1.0 0.0.0.255 any
control-plane
vstack
banner motd ^C
AUTHORIZED ACCESS ONLY
^C
line con 0
exec-timeout 0 0
password AlphaBravo9
login
stopbits 1
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
exec-timeout 120 0
login local
length 0
transport input none
scheduler max-task-time 5000
scheduler allocate 20000 1000
end
SHow IP int
Lab2921#show ip int
Embedded-Service-Engine0/0 is administratively down, line protocol is down
Internet protocol processing disabled
GigabitEthernet0/0 is down, line protocol is down
GigabitEthernet0/1 is up, line protocol is up
Internet address is 10.0.1.1/24
Broadcast address is 255.255.255.255
Address determined by setup command
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Local Proxy ARP is disabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is enabled
IP fast switching on the same interface is disabled
IP Flow switching is disabled
IP CEF switching is disabled
IP Null turbo vector
IP multicast fast switching is enabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast, No CEF
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Policy routing is disabled
Network address translation is enabled, interface in domain outside
BGP Policy Mapping is disabled
Input features: Common Flow Table, Stateful Inspection, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, NAT Outside, MCI Check
Output features: Post-routing NAT Outside, Common Flow Table, Stateful Inspection, NAT ALG proxy
IPv4 WCCP Redirect outbound is disabled
IPv4 WCCP Redirect inbound is disabled
IPv4 WCCP Redirect exclude is disabled
GigabitEthernet0/2 is administratively down, line protocol is down
NVI0 is up, line protocol is up
Internet address will be negotiated using IPCP
MTU is 1514 bytes
IP fast switching is disabled
IP route-cache flags are Fast, CEF
Network address translation is disabled
Input features: MCI Check
Output features: Post-routing NAT NVI Output
47 Replies 47
The address with 172.20.10.5 is the address my hotspot was giving when I connected it to my computer via usb to keep internet access while testing.  Please note, that when performing any tests, I would disable that network adapter so it didnt' cause any issues.  I apologize for sending the screenshot with both on there, I had taken two, and the one I didn't save only had the ethernet adapter that had the cable from the router.
So does that change your thoughts on this?
Here is a better capture of the info if it helps.
full dump.PNGAls
Also, here are the dumps of show ip int gig0/0 which I found interesting.....
Lab_2921#show ip int br
Embedded-Service-Engine0/0 unassigned YES unset administratively down down
GigabitEthernet0/0 69.180.36.8 YES DHCP up up
GigabitEthernet0/1 10.0.1.1 YES manual up up
GigabitEthernet0/2 unassigned YES unset administratively down down
NVI0 unassigned YES unset up up
Lab_2921#show ip int gig0/0
GigabitEthernet0/0 is up, line protocol is up
Internet address is 69.180.36.8/23
Address determined by DHCP
MTU is 1500 bytes
IP multicast fast switching is disabled
IP route-cache flags are No CEF
Thanks for the explanation about the second IP address. When I first saw that output I suspected that the second address might be part of the problem. But as I looked further I found a problem on your 10.0.1.2 interface and thought that the second IP address did not cause your problem.
The fundamental issue is that your PC does not have a default gateway. It can communicate with things that are on the same subnet but is not able to communicate with things that are on remote subnets. Go back to the configuration of your router and put the default router parameter into your DHCP scope and then test again.
You comment that you found the output of show ip int gig0/0 interesting. What did you find interesting in it?
Rick
Rick
So I totally agree about the PC not picking up a default gateway, but I'm not sure how to get it to do so.  I've added a default-gateway to int gig0/1 as well as adding it to my DHCP pool, but as you can see it's still not picking it up....am I missing how to do so?  Here is the output of the PC as well as the show run and show ip int.
I feel like we are really close, but just need to close this out.  Thank you again so so much for your help!
PC Status.PNGh
Lab_2921>show run
% Invalid input detected at '^' marker.
Lab_2921>ena
Lab_2921#show run
Current configuration : 1971 bytes
! Last configuration change at 09:02:51 EST Thu Mar 28 2019 by davidstriplin
! NVRAM config last updated at 08:32:13 EST Thu Mar 28 2019 by davidstriplin
version 15.7
hostname Lab_2921
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone EST -5 0
ip dhcp excluded-address 10.0.1.170
ip dhcp pool Inside DHCP
ip dhcp class any
no ip domain lookup
ip cef
no ipv6 cef
username davidstriplin secret 5 $1$j5Ka$6u.mf3wInjRpFMZ2PRLxY.
redundancy
no ip address
shutdown
description Facing The ISP (WAN)
ip address dhcp
ip nat outside
no ip route-cache
duplex auto
speed auto
description Facing The LAN (LAN)
ip nat inside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip http server
control-plane
vstack
line con 0
logout-warning 120
login local
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login local
end
Lab_2921>show ip dhcp pool
Pool Inside DHCP :
Utilization mark (high/low) : 100 / 0
Subnet size (first/next) : 0 / 0
Total addresses : 254
Leased addresses : 1
Pending event : none
1 subnet is currently in the pool :
Current index IP address range Leased addresses
10.0.1.3 10.0.1.1 - 10.0.1.254 1
Lab_2921>show ip int gig0/1
MTU is 1500 bytes
IP CEF switching is enabled
IP CEF switching turbo vector
Network address translation is enabled, interface in domain inside
Input features: Common Flow Table, Stateful Inspection, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, MCI Check
Output features: NAT Inside, Common Flow Table, Stateful Inspection, NAT ALG proxy
In the DHCP pool in your router config add the statement default-router 10.0.1.1
If you look at some of the early posts in this discussion you will find it there. Somewhere along the line it was removed. Now you need to put it back.
Rick
Rick
And we are good to go!  I am currently writing this using the configuration that you helped me create and I'm browsing on the internet through the Cisco router hooked directly to my PC!!!!!!!!
Seriously, I want to sincerely thank you for taking time out of your day and helping me so much, it is greatly appreciated!
Just for grins....here is the current show run and show ip int so you can see if everything else looks good.
MTU is 1500 bytes
MTU is 1500 bytes
MTU is 1514 bytes
Lab_2921#
Lab_2921#show run
Current configuration : 1993 bytes
! Last configuration change at 09:33:53 EST Thu Mar 28 2019 by davidstriplin
! NVRAM config last updated at 09:26:26 EST Thu Mar 28 2019 by davidstriplin
version 15.7
hostname Lab_2921
boot-start-marker
boot-end-marker
no aaa new-model
dns-server 75.75.75.75 75.75.76.76
ip dhcp class any
no ip domain lookup
ip cef
no ipv6 cef
redundancy
no ip address
shutdown
ip address dhcp
ip nat outside
no ip route-cache
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip http server
ip dns server
control-plane
vstack
line con 0
logout-warning 120
login local
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login local
end
You are quite welcome. I am glad that our suggestions have been helpful. It has been a group effort and I am happy that it now is working for you successfully. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
In looking at the config that you posted and the interface information I notice a couple of things. First and most important is that I do not see the default-router command in the DHCP scope. It must have been there because the ipconfig does have a default gateway. But I do not see it in the running config that you posted and that is concerning.
Also I notice that interface Gig0/0 has fast switching and cef switching disabled. This is because of the command no ip route-cache  that is configured on the interface. It is not a big deal but I would suggest that you enable them this way
interface gig0/0
ip route-cache
end
Otherwise I believe that you are good to go.
Rick
Rick
Rick,
Done as requested.  Here is the output of show run to confirm.
Lab_2921#show dhcp pool InsideDHCP
Lab_2921#show ip dhcp pool
Pool Inside DHCP :
Leased addresses : 9
10.0.1.19 10.0.1.1 - 10.0.1.254 9
Lab_2921#
Lab_2921#
MTU is 1500 bytes
MTU is 1500 bytes
MTU is 1514 bytes
Lab_2921(config)#int gig0/0
Lab_2921(config-if)#ip route-cache
Lab_2921(config-if)#exit
Lab_2921(config)#exit
Lab_2921#cop
Mar 28 15:30:59.779: %SYS-5-CONFIG_I: Configured from console by davidstriplin o n console
Lab_2921#copy run
Lab_2921#copy running-config st
Lab_2921#copy running-config startup-config
Destination filename [startup-config]?
[OK]
Lab_2921#co
Lab_2921#cop
Lab_2921#copy ru
Lab_2921#copy running-config tftp
Address or name of remote host []? Lab 2921 Config_WORKING_ 3-28-2019
?Invalid host address or name
%Error parsing filename (Invalid IP address or hostname)
Address or name of remote host []? 10.0.1.3
Destination filename [lab_2921-confg]? Lab 2921 Config_WORKING_ 3-28-2019
1996 bytes copied in 0.256 secs (7797 bytes/sec)
Lab_2921#copy
Lab_2921#copy r
Lab_2921#copy ru
[OK]
Lab_2921#show run
Current configuration : 1996 bytes
! Last configuration change at 10:30:59 EST Thu Mar 28 2019 by davidstriplin
! NVRAM config last updated at 10:32:53 EST Thu Mar 28 2019 by davidstriplin
version 15.7
hostname Lab_2921
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp class any
no ip domain lookup
ip cef
no ipv6 cef
redundancy
no ip address
shutdown
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip http server
ip dns server
control-plane
vstack
line con 0
logout-warning 120
login local
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login local
transport input ssh
end
We made some progress but are not quite there yet. Please add these commands to the config
interface gig0/0
ip route-cache cef
Rick
Rick
Rick,
Thanks again....you helped another issue that I wasn't going to bother you with but it also allowed my wireless clients to start connecting when I plugged my AP in!
Here is the output of show run an show ip int
Lab_2921#show run
Current configuration : 2018 bytes
! Last configuration change at 12:36:32 EST Thu Mar 28 2019 by davidstriplin
! NVRAM config last updated at 12:36:39 EST Thu Mar 28 2019 by davidstriplin
version 15.7
hostname Lab_2921
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp class any
no ip domain lookup
ip cef
no ipv6 cef
redundancy
no ip address
shutdown
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip http server
ip dns server
ip ssh time-out 60
control-plane
vstack
line con 0
logout-warning 120
login local
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login local
transport input ssh
end
MTU is 1500 bytes
MTU is 1500 bytes
MTU is 1514 bytes
It is looking good to me. I think now you are good to go.
Rick
Rick
Rick, thanks again, I appreciate everything.
Dave
Please add default Gateway on your system.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Thank you so much for helping.  I've made the changes as requested, but still no internet access.  BTW, when I say internet access, I'm talking about web browsing on Chrome, not trying to ping another address if that makes a difference to you at all.  Here are the outputs of show run, show arp.
PC Address - 10.0.1.3
GW - 10.0.1.1
DNS 8.8.8.8 8.8.4.4
Lab_2921#show arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 10.0.1.1 - f872.ea8c.0ed1 ARPA GigabitEthernet0/1
Lab_2921#show run
Current configuration : 1919 bytes
! Last configuration change at 14:31:03 UTC Wed Mar 27 2019
version 15.7
hostname Lab_2921
boot-start-marker
boot-end-marker
no aaa new-model
import all
network 10.0.0.0 255.0.0.0
class any
ip dhcp class any
no ip domain lookup
ip cef
no ipv6 cef
redundancy
no ip address
shutdown
ip address dhcp
ip nat outside
no ip route-cache
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip http server
ip route 0.0.0.0 0.0.0.0 dhcp
control-plane
vstack
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login
end
