04-25-2007
02:49 AM
- last edited on
03-25-2019
03:14 PM
by
ciscomoderator
Hi everyone!I have boot problem with Cisco831-k9-64! My router boot only rommon with this warning: "WARNING: Cookie information is corrupt". And cookie is empty. I need cookie for may router!!! Please HELP ME!!!
04-25-2007 03:58 AM
did you try formatting the flash and reloading the ios onto it ?
The procedure would be backup the ios file then format the flash.
Once you are done with the format upload the file onto the disk..
Try booting from the ios loaded on the disk.
regds
04-25-2007 04:12 AM
Mi problem is - http://www.tech-recipes.com/cisco_router_tips982.html
I want to find cookie example for my router.
03-05-2008 09:57 AM
Has this issue been addressed? i am having the same problem.. but now i am locked out of the 'priv' command to change the cookie
please HELP
