WCCP doubts
william2u
(Web cache system)+ (User) --- (e0/1)R1(e0/0)
---(Internet)
R1:
Ip wccp web-cache
Int e0/0
Ip wccp web-cache redirect out
* my question is , do i need any command for e0/1 ? since the web cahce system + user is ther ?
* do i miss anythings ?
Giuseppe Larosa
Hello William,
that command should be enough
I have some concerns on having users and web cache out the same interface usually you need to use three logic interfaces: users, web cache, internet
Hope to help
Giuseppe
Giuseppe Larosa
Hello William,
Hope to help
Giuseppe
ok.. thanks for your precious answer
Mohamed Sobair
Level 7
Level 7
William,
you need to redirect HTTP requests towards the WCCP system which is located across e0/1 interface.
the command should be configured on e0/1 and not e0/0.
Mohamed
