WCCP in and out simultaneously
PJ
Hi All,
Is it ok to define WCCP in both directions on the serial (WAN) interface using two different WCCP service groups? The NAT is performed on the router. We would like to have client source ip in the NAT table instead of the WAE as inside address.
interface s1
ip wccp 90 redirect out
ip wccp 91 redirect in
ip nat outside
int g1/1 - WAE
ip wccp redirect exclude in
int g1/2 -clients
ip nat inside
90 - Destination Hash for ports 80, 443, 554 and 1755
91- Source hash for ports 80,443,554,and 1755
Thanks.
Nicolas Fournier
Hi Praful,
Even if we usually try to put the two services on different interfaces, it is ok to have both of them in and out of the same interface.
Just keep in mind that WCCP is applied before NAT.
Nicolas
