WCCP issues - fail open
carl_townshend
HI All
Can anyone tell me, when I use a acceleration device such as a Riverbed etc, when using WCCP, if the Riverbed fails.
What will happen?
Will the traffic just route as normal?
cheers
rasmus.elmholt
Level 7
Level 7
Yes, if the WCCP connection to the Caching device is not negotiated traffic will be routed normally.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/15-02SG/configuration/guide/config/wccp.pdf
balaji.bandi
in the ACL last you can add below line, should able to route the traffic. ( depends on IOS)
access-list  XX permit ip any any  < in the end of should work for you. test and advise.
BB
rasmus.elmholt
Level 7
Level 7
