WCCP VRF Aware - IOSXE License Requirements
Daniel Lucas
Looking for WCCP VRF-Aware requirements on a 4500E switch - looks like it was introduced in XE version 3.8. Release notes state Enterprise Services is required, but the feature navigator says IPBase supports it. Anyone know which is true?
-Thanks
Diana Karolina Rojas
Hello Daniel,
I look into the feature navigator and you can use that feature in a Catalyst 4500 IP base 3.8.0E software release with SUP8-E, If you want you can send me the "show version" and I can help you to search that information for you especific release, I also need to know what Supervisor model are you using.
Do not forget to rate/mark useful answers.
Thanks for the response,
Yes, I see that listed in the feature navigator - however, the release notes for 3.8 state that Enterprise services is required:Capture.PNG
Customer currently has IPBase, and I need to determine if they will need to upgrade the licenses - I don't currently have access to the equipment to check if the commands are available.
-Thanks
