What is probably causing below EIGRP neighbor adjacency flapping?
MicJameson1
Hello.
Below are logs from CSR_1000v.
May you please suggest the best commands to troubleshoot below?
Thank you!
(obfuscated)...
*Jul 10 16:48:46.961: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 192.168.30.44 (Tunnel77) is down: retry limit exceeded
*Jul 10 16:48:49.554: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 192.168.30.44 (Tunnel77) is up: new adjacency
*Jul 10 16:50:09.064: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 192.168.30.44 (Tunnel77) is down: retry limit exceeded
*Jul 10 16:50:12.699: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 192.168.30.44 (Tunnel77) is up: new adjacency
*Jul 10 16:51:32.205: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 192.168.30.44 (Tunnel77) is down: retry limit exceeded
*Jul 10 16:51:35.640: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 192.168.30.44 (Tunnel77) is up: new adjacency
*Jul 10 16:52:55.148: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 192.168.30.44 (Tunnel77) is down: retry limit exceeded
12 Replies 12
if tunnel77 is DMVPN tunnel
if router have two or more DMVPN tunnel with same source interface
AND IF tunnelS use same tunnel key then this can happened
Hi MHM.
if tunnel77 is DMVPN tunnel = TRUE
if router have two or more DMVPN tunnel with same source interface =TRUE
tunnels use same tunnel key = FALSE.
additional data...
-tunnel protection ipsec profiles are different= TRUE
-tunnels themselves are not flapping. = TRUE
Please advise.
you answer is excellent,
will check via LAB.
thank
MHM
fyi..
(obfuscated & output ommitted)
2921#sh run int tu20
interface Tunnel66
bandwidth 100000
ip address 192.168.102.66 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication ALPHA1
ip nhrp map multicast 216.1.1.1
ip nhrp map 192.168.1.1 216.1.1.1
ip nhrp network-id 66
ip nhrp nhs 192.168.1.1
ip tcp adjust-mss 1360
tunnel source GigabitEthernet0/1
tunnel mode gre multipoint
tunnel key 6666
tunnel vrf VRF66
tunnel protection ipsec profile PROFILE66
end
2921#sh run int tu77
Building configuration...
Current configuration : 457 bytes
interface Tunnel30
bandwidth 20000
ip address 192.168.2.2 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication BETA1
ip nhrp map 192.168.77.1 52.1.1.1
ip nhrp map multicast 52.1.1.1
ip nhrp network-id 77
ip nhrp holdtime 450
ip nhrp nhs 192.168.77.1
ip nhrp redirect
tunnel key 7777
tunnel protection ipsec profile PROFILE77
end
The initial data was from the hub device. The above data is from the spoke device.
The spoke shows that currently the hub is NOT an EIGRP neighbor.
Hub data below...
CSR_1000v_HUB#sh run int tu77
interface Tunnel77
bandwidth 700000
ip address 192.168.77.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp redirect
delay 1000
tunnel source GigabitEthernet1
tunnel key 7777
end
tunnel vrf VRF66 <<- why tunnel vrf, are you use front-VRF in your router ?
There are three total tunnels on spoke-- tu55,tu66,tu77.
66 and 77 use same interface.
55, 66 use different interfaces to same (other) 66 hub. tu77 hub is different device than tunnel 66 hub.
hub66, hub 77 have NO connection between them at all.
Below is VRF info from the 77 hub 1000v router...
(I don't understand info below. I do not believe we are using VRF on the hub. Spoke has strange situation, it is unique config using VRF. I believe this was done because we use two ISPs for two tunnels to same tu66 device.)
(Hub77 1000v)#sh vrf ipv4 br
Name        Default RD         Protocols          Interfaces
FVRF          <not set>             ipv4
GS             100:100              ipv4
I run lab test two tunnel two profile two key and it work.
What I notice here is holdtime is high 450 I think register timeout is more less than hold time and this make Hub remove this tunnel and make eigrp flapping.
Check register timeout in hub
MHM
IOU3# show runb
IOU3# show runb
% Invalid input detected at '^' marker.
IOU3#show run
IOU3#show running-config
Current configuration : 2963 bytes
! Last configuration change at 08:20:47 UTC Wed Jul 12 2023
version 15.5
hostname IOU3
boot-start-marker
boot-end-marker
no aaa new-model
bsd-client server url https://cloudsso.cisco.com/as/token.oauth2
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip icmp rate-limit unreachable
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
redundancy
ip tcp synwait-time 5
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key mhm address 0.0.0.0
crypto ipsec transform-set mhm esp-des
mode tunnel
crypto ipsec profile mhm15
set transform-set mhm
crypto ipsec profile mhm5
interface Loopback0
ip address 3.3.3.3 255.255.255.255
interface Tunnel0
ip address 5.0.0.3 255.255.255.0
no ip redirects
ip nhrp map 5.0.0.1 100.0.0.1
ip nhrp map multicast 100.0.0.1
ip nhrp network-id 5
ip nhrp nhs 5.0.0.1
tunnel source Ethernet0/0
tunnel key 5
tunnel protection ipsec profile mhm5
interface Tunnel1
ip address 15.0.0.3 255.255.255.0
no ip redirects
ip nhrp map 15.0.0.2 110.0.0.2
ip nhrp map multicast 110.0.0.2
ip nhrp network-id 15
ip nhrp nhs 15.0.0.2
tunnel key 15
tunnel protection ipsec profile mhm15
interface Ethernet0/0
ip address 120.0.0.3 255.255.255.0
interface Ethernet0/1
no ip address
shutdown
interface Ethernet0/2
no ip address
shutdown
interface Ethernet0/3
no ip address
shutdown
interface Ethernet1/0
no ip address
shutdown
interface Ethernet1/1
no ip address
shutdown
interface Ethernet1/2
no ip address
shutdown
interface Ethernet1/3
no ip address
shutdown
interface Serial2/0
no ip address
shutdown
serial restart-delay 0
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
interface Serial3/0
no ip address
shutdown
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
router eigrp 5
network 3.3.3.3 0.0.0.0
network 5.0.0.0 0.0.0.255
network 15.0.0.0 0.0.0.255
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 120.0.0.4
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
transport input none
THnak you MHM.
"What I notice here is holdtime is high 450 I think register timeout is more less than hold time and this make Hub remove this tunnel and make eigrp flapping.
Check register timeout in hub"
How do I check this? What are commands?
Hello Team.
Because of the strict nature of this enterprise I cannot troubleshoot this tunnel until a service window is opened. That will not be for two weeks.
I will update this thread at that time.
Thank you for your inspired effort.
Can you provide the configuration between the 2 devices giving this error along with a diagram?
Additionally if you take the IPSEC profiles off does the neighborship form without issue? If that's the case your issues is likely the IPSEC configuration.
Hello
interface Tunnel66
bandwidth 100000
no ip redirects
ip mtu 1400
tunnel key 6666
tunnel vrf VRF66
end
interface Tunnel30
bandwidth 20000
no ip redirects
ip mtu 1400
ip nhrp redirect
tunnel key 7777
end
Hub data below...
interface Tunnel77
bandwidth 700000
no ip redirects
ip mtu 1400
ip nhrp redirect
delay 1000
tunnel key 7777
end
Append the following and test again:
NHS - Hub
Int tun xx
 ip nhrp map multicast dynamic
no ip next-hop-self eigrp xx
no ip split-horizon eigrp xx
NHC -client
Int tun xx
Kind Regards
Paul
