What Router for this network?
invelcosa
Hi!
I need choose a router to interconnect Control Centre with several remote stations, what router model is recommended fot this network?
The link subsystem will need to link the equipment that will be installed in the different remote stations. There are six remote stations in total, which will be linked to the Main Control Center in Department of Merchant Shipping, and from the Main Control Centre it will be a separate link to connect the Secondary Control Center in JRCC/Larnaca. In addition, the Control Centers will act as an operational post from where the equipment on the remote stations will be managed remotely.
In all remote stations, the equipment will be linked to a router that will be a gateway to the Main Control Center. The links between the Main Control Center and the remote stations in Lara, Kremni, Fanos, Orites, Polemidia and Chionistra will be linked to the Main Control Centre by means of a Metro Ethernet Network. The link subsystem should interface with the Metro Ethernet network according to the specifications shown in the table below
Physical Interface
ΙΕΕΕ 803-3-2002, UTP, RJ45, 10/100/1000 Mbps
Standards
  • IEEE 802.3x full duplex
  • IEEE 802.1p CoS classification (optional - only if utilised by customer)
  • IEEE 802.1Q VLAN
  • IEEE 802.3 10BASE-T (for access speeds ≤ 10 Mbps)
  • IEEE 802.3u 100BASE-T (for access speeds = 100 Mbps)
  • IEEE 802.3ab 1000BASE-T (for access speeds = 1000 Mbps)
The Secondary Control Centre (JRCC/Larnaca) will be connected with the Main Control Centre by using Ethernet interface as well.
Greatings
paolo bevilacqua
To choose a router you need to specify the circuit speed from ISP. E.g. 2 or 20 or 200 Mbps.
not specified in the features, but I guess it will be 12 mb
You can use, for example, an 881.
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Or, for 2x the performance, an 890 series.  This would provide a bit more "headroom".
