Cisco 2951 Memory
ledzepp817
I have 4 GB installed in 2951 but only 2 GB show up.  Am I missing something?
Total memory size = 4096 MB - DIMM0 = 2048 MB, DIMM1 = 2048 MB
CISCO2951/K9 platform with 4194304 Kbytes of main memory
Main memory is configured to 72/72(dimm 0/1) bit mode with ECC enabled
Installed image archive
Cisco CISCO2951/K9 (revision 1.1) with 1835264K/261888K bytes of memory.
3 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
4001760K bytes of ATA CompactFlash 1 (Read/Write)
turnera
If I am reading the following correctly, the maximum memory for that  router is 2.5 Gb. The second stick is probably being ignored because it  is too large to begin with.
http://www.cisco.com/en/US/docs/routers/access/2900/hardware/installation/guide/Overview.html#wp1071964
Cisco 2951
Expansion Type—VLP RDIMM with ECC.
VLP RDIMM sizes—512 MB, 1 GB, 2 GB.
VLP RDIMM slots—2.
Default VLP RDIMM memory module — One 512 MB module (slot 0)
Maximum memory—2.5 GB.
It looks as though you can put a 512 MB DIMM in slot 0 and a 2 GB DIMM in slot 1 and that will be it.
