what's IOS of cisco 2600 support ssh 2.0
HWangLoyalty_2
I have a 2621XM router.The IOS version of 12.3(21), it is ENTERPRISE PLUS IPSEC 3DES ,but it only supports SSH 1.5. I think I have to upgrade IOS to fix it if I need SSH 2.0. How about ADVANCED ENTERPRISE SERVICES Vesion. Could you tell me which version could make it? Thanks first:)
williamsdo
Level 3
Level 3
Hi, you can look that information up yourself by using the feature navigator and then download the IOS from Cisco site, click on the links below for detail information. HTH
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
http://www.cisco.com/kobayashi/sw-center/sw-ios.shtml
Edison Ortiz
c2600-entservicesk9-mz.124-19.bin (12.4(19)) should give you what you need.
HTH,
__
Edison.
Certainly the 12.4(19) suggested by Edison will support SSHv2. The feature navigator shows support for SSHv2 server was added in 12.3(4)T. So it is in the T train of 12.3 and in main line code of 12.4. So anything after that versions 12.3(4)T (with the appropriate feature set) should give support for SSHv2.
Rick
Rick
