ā05-09-2013 09:24 AM - edited ā03-04-2019 07:51 PM
Customer has a pair of Cisco 3745 configured with DLSW+...He is in a technological migration phase so he needs to migrate to new cisco platforms.
How can I find out which cisco products (switches, routers) support DLSW+ to replace the 3745s?
I am in a little pressure...:(
Any help will be appreciated !!
guruiz
Solved! Go to Solution.
ā05-09-2013 11:21 AM
Hello Guruiz, I tried to find this too, before I was posting, but I wasn't able to download the products in excel but no option there. I can get you information about the IOS on a certain platform in the excel.
You can also do this if you want by using the feature navigator. But unfortunately can't get you the list. You will be able to have a look at the list if you view and search on the tool.
Hope this helps
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
ā05-09-2013 10:10 AM
Hello Guruiz, you can have a look on the Cisco Feature Navigator to see which products support DLSW+
http://tools.cisco.com/ITDIT/CFN/jsp/by-feature-technology.jsp
Hope this helps
ā05-09-2013 10:27 AM
Bilal,
I am very grateful with your soon relpy !!
I noticed I can download to excel all feature set for a specific platform (e.g. 7200, 3845), but do you know if there is a way to download all product list information, that is displayed on the bottom left?
Thanks for your comments.
guruiz
Hope this helps
ā05-09-2013 01:32 PM
Bilal,
Sure it is.
Wonderful answer.
Thank you so much !
guruiz
