Which router is best fit to my topolgy
habarya
Any body can help me which router is best fit to my network topology which has three fastethernet accroding to my network topology and which is going to place under core layer of my campus network which has not much traffics.In addition to this it has to have a NAT faction to have an internet connection with the external; system. In Addition to that the one that cost me low!!!!!!!!!
paolo bevilacqua
do yo need wire-speed routing on the three fast-ethernet ? If so, the best would be a L3 switch like a 3560 or 3750 for this. Then for internet access you can use pretty much anything from the 871 and up.
Amit Singh
After understading by your explanation that you need a very basic router with NAT support, 871 router should be fit in for your requirement.
Please see the datasheet below:
http://www.cisco.com/en/US/products/hw/routers/ps380/products_data_sheet0900aecd8028a976.html
Please check the feature navigator link below for any specific feature support on the router:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
HTH,Please rate if it does.
-amit singh
