SH DSL INTERFACE ATM0 output description
a.shaukat
Im running Cisco 877 and 837 on my branch offices... both connec using ADSL lines to the same ISP at 256Kbps and 128Kbps respectively
Branch1 seems to run noticably slow,
can anyone please help me understand the following parameters of
sh dsl int atm0
>capacity used
>noise margine
>output power
>attenuation
>interleave speed(kbps)
the noise factors and capacity used seems to be abnormal compared to the other branch
also the Set MTU values for the problem branch is set out to be way higher then the usual 1500 as well as the delay
the bandwidth of this routers interface is set at a lower value (this router connets to the isp at 256Kbps)
while the other branch router's interface bandwidth is set at a higher value (which connects to the isp at 128Kbps)
quiet confusing... can any one help
paolo bevilacqua
See, by coincidence today a lot of people is talking about ADSL problem with the 800 router. Your 877 does not appear to be running the latest firmware. You can either upgrade the router to 12.4(11)XJ3 or try upgrade the DSL fimrmare only at ftp://ftp.cisco.com/pub/access/800
The bandwidth parameter is information only, does not influence performances, and you can remove it without making any difference.
Also please reset the MTU to the default because it won't change anything.
Possibly these chances were made by someone attempting to improve performances without really knowing what he was doing.
hmm ok il reset the MTU..
what abt the bandwidth values ?? how do i figure out what value to set .. and even on a new router this value seems to be different on different routers... whats the theory behind it like how does a router sense what bandwidth to set on this ADSL interface.... i have 640 on most of my routers
Hi, whatever value you will set for bandwidth, it won't change anything in actual router behavior or performance,as I said above it is just an informative parameter used by some routing protocols (that you don't use), so just configure "no bandwidth" and the command will go away making the configuration smaller and easier to read.
As a recognition to those providing answers, please rate all useful post with the scrollbox below!
