05-09-2021 11:10 PM - last edited on 12-12-2023 11:03 PM by Translator
I created a test OSPF network and the LSDB of the area 0 is as following.
R1#sh ip ospf data
OSPF Router with ID (192.168.3.1) (Process ID 1)
Router Link States (Area 0)
Link ID ADV Router Age Seq# Checksum Link count
192.168.9.1 192.168.9.1 1655 0x80000011 0x00e1ad 2
192.168.5.1 192.168.5.1 402 0x80000016 0x008723 3
192.168.3.1 192.168.3.1 392 0x80000017 0x00b204 3
192.168.7.1 192.168.7.1 392 0x8000000e 0x00c7d2 2
Net Link States (Area 0)
192.168.4.2 192.168.7.1 1709 0x80000003 0x008191
192.168.1.2 192.168.5.1 1693 0x80000002 0x004aed
192.168.5.2 192.168.9.1 1660 0x80000004 0x0053bc
192.168.3.2 192.168.9.1 1655 0x80000003 0x00e153
192.168.2.2 192.168.7.1 392 0x80000003 0x00e142
Summary Net Link States (Area 0)
192.168.10.0 192.168.9.1 1754 0x80000005 0x002e43
192.168.6.0 192.168.7.1 674 0x80000003 0x005823
192.168.7.0 192.168.7.1 674 0x80000004 0x00c376
192.168.8.0 192.168.9.1 117 0x80000006 0x00a68e
192.168.9.0 192.168.9.1 107 0x80000007 0x002151
192.168.11.0 192.168.9.1 5 0x80000008 0x00135b
And when I searched OSPF neighbors, I got 3 designated routers which are only other 3 routers in the area.
Can someone please explain me the reason for this.
Thanks in advance.
Solved! Go to Solution.
05-09-2021 11:22 PM
Hello @mad_mavula ,
what you see is normal an OSPF DR is elected for each LAN segment or more correctly for each link of type broadcast of other type that requires a DR to be elected.
As you can see from your show ip ospf neighbors all the listed nerighbors are DR in their associated link subnet, but they are seen out of different local interfaces in different IP subnets.
This is normal
DR is a per broadcast link concept not per area concept.
Hope to help
Giuseppe
05-09-2021 11:22 PM
Hello @mad_mavula ,
This is normal
Hope to help
Giuseppe
05-09-2021 11:25 PM
Thanks for your help.
05-10-2021 09:11 AM
As Giuseppe correctly notes, DR is per shared (i.e. broadcast) LAN segment.
However, did want to add, you can set priorities for router DR elections.
For example, given:
R1<shared1>R2<shared2>R3
Both shared segments would have a DR and BDR, but R1 and R2 would be the candidate routers for shared1 while R2 and R3 would be the candidate routers for shared2. I.e. you might have R1 and R3 as DRs, or R2 (for shared1) and R3 as DRs, or R1 and R2 (for shared2) as DRs, or R2 as DR (for both shared1 and shared2).
