why no BGP route in Generic Router in Packet Tracer?
Maivoko
I use DTE connect two Generic Router in packet tracer, but no BGP route
Router2#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is not set
C 192.168.0.0/24 is directly connected, Serial2/0
Router 2
conf t
hostname Router2
int f0/0
ip address 172.16.0.2 255.255.0.0
no shut
int s2/0
clock rate 2000000
ip address 192.168.0.2 255.255.255.0
no shut
end
Router 3
conf t
hostname Router3
int f0/0
ip address 10.10.1.2 255.0.0.0
no shut
int s2/0
clock rate 2000000
ip address 192.168.0.1 255.255.255.0
no shut
end
Router 2
conf t
router bgp 200
neighbor 192.168.0.1 remote-as 300
network 172.16.0.0
network 192.168.0.0
end
Router 3
conf t
router bgp 300
neighbor 192.168.0.2 remote-as 300
network 10.0.0.0
network 192.168.0.0
end
10 Replies 10
Vinit Jain
Two things to check:
1. Check if the BGP neighbor is up
2. Use the network statement with the subnet mask as below:
network 10.0.0.0 mask 255.0.0.0
Same for 192.168.0.0/24 network as well.
Unless the BGP neighbor is UP and advertising the prefix from router 3, Router 2 will not be able to see the route.
--Vinit
in router 3
has error
why both are EBGP but have this message
%Packet Tracer does not support internal BGP in this version. Only external neighbors are supported.
make sure the configs look as below:
Router 2
hostname Router2
interface FastEthernet0/0
interface Serial2/0
clock rate 2000000
router bgp 200
network 172.16.0.0 mask 255.255.0.0
network 192.168.0.0 mask 255.255.255.0
Router 3
hostname Router3
int Serial2/0
clock rate 2000000
router bgp 300
neighbor 192.168.0.2 remote-as 200
Your serial port and  FastEthernet port are not up u should use the No shutdown command .
I find error come from remote as using 300 in router 3 but not remote as 200
solved
EBGP already up, but why still no bgp route?
all are up but no BGP route
Make sure on Router 3, the interface fa0/0 is in UP state so that the route is present in the RIB (routing table) before it is advertised via BGP.
Also, if you want to practice BGP or other routing protocols, i would recommend using GNS3 or something like VIRL or EVE.
--Vinit
succeed , it need to connect a PC to fa0/0
by the way, can packet tracer simulate internal BGP  such as
1. route reflector
2. weight, local preference,AS Path, origin MED these situation?
