What is the best way to implement a switch stack downlink ports? stp?
aannuupp1
Switch A and Switch B are already configured as in the diagram.
Trying to add a switch stack upstream of A and B
Currently, interface 1/2 cabling does not exist. and 1/1 has IP address 10.0.0.150/24
Solutions.....
1. On switchstack Configure SVI on Vlan 10 and (switchport access VLAN 10) down 1/1 and 1/2?
2. Or configure an IP address on interface 1/1 or 1/2 ?
3. is there a way to implement a port channel?
How does the spanning tree behave? What is recommended solution?
7 Replies 7
Leo Laohoo
Keep it simple:  Remove the link between Switch A and Switch B.
The uplinks from the access switch to the 3750X stack should be going to the switch members (one each) and then etherchannel.
Forming a "pyramid" is just "old school" and "textbook" cases.  In large deployment, no one does that anymore.
balaji.bandi
The best approach is to make it longer stable.
1. Move the VLAN Layer3 Interface towards Stack 10.0.0.254 VLAN 10
2. Make a Trunk port between Stack switch and Switch A (if you have more ports, make a port-channel in case 1 link fail other can take care) spread the links stack different switch,
3. Make a Trunk port between Stack switch and Switch B  (same case as above)
4. Remove the Link between Switch A and B, this will have no spanning-tree loops.
Note: the suggestion made based on the information, thinking all in the same Campus Lan.
Other notes: Maybe a typo i guess here, your Pc left side IP address and VLAN 10 IP address of SwitchB is the same?
BB
--Yes same subnet, vlan 10 (10.0.0.0/24) all over.
I mean your PC 10.0.0.10/24  also same IP configured vlan 10 on switch B 10.0.0.10/24
BB
Typo, yup. Thanks.
make it streamline below diagram help you : since you got opportunity  correct it ( so you can use IP address in good way)
BB
I too would recommend a topology like @balaji.bandi shows.
Additionally, would try to avoid running the same VLAN across multiple (separate - like your switches A and B) switches.  Would also recommend cross stack links from you stack up to the "core router" (might be L2 PO or L3 p2p).
One of the major feature of a stack is to minimize single points of failure.
