Why there are MPLS routes on my 7604 router?
danielchau
HI all,
I Have a 6509 router running in production environment, but I am planning to switch it to a 7604 router.
While I dont have the problem of the config between them, it seems that from a unknown reason, there is some MPLS routers that exists on the new router:
Here is the 6509 router output:
6509#show mls cef summary
Total routes:                                    636416
    IPv4 unicast routes:                         636393
        IPv4 non-vrf routes:                     636393
        IPv4 vrf routes:                         0
    IPv4 Multicast routes:                       4
    MPLS routes:                                 1
    IPv6 unicast routes:                         14
        IPv6 non-vrf routes:                     14
        IPv6 vrf routes:                         0
    IPv6 multicast routes:                       3
    EoM routes:                                  1
But on my 7604: (not in production)
7604#show mls cef summary
Total routes:                     2089
    IPv4 unicast routes:          29
    MPLS routes:                  2048
    IPv6 unicast routes:          8
    EoM routes:                   0
I don&t understand why there are MPLS routes while i do not intentionally use, or enabled any vrf, or MPLS functions.
How can i know how this 2048 MPLS routes comes from?
Daniel
Have you configured MP-BGP on your router? or have you established any mpls neighbor?
show bgp vpnv4 unicast summary
show mpls ldp neighbor
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio,
Thanks, I dont think i have setup MP-BGP . I do have ISIS with BGP on the router.
Here is the result on my 7604 with the suggested commands:
7604#show bgp vpnv4 unicast summary
% Invalid input detected at '^' marker.
7604#show mpls ldp neighbor
7604#
Daniel
