Redundancy with 2 static routes in 2 routers
Chin
Appreciate if someone can help to pinpoint what is my error when I configure 2 static routes in 2 routers for redundancy. But I can't failover to each other until I need to remove and re-add the route.
I have 2 routers 2901 routers and connecting to a 2960 switches.
RouterA
track 100 ip sla 100 reachability
delay down 30 up 30
interface GigabitEthernet0/0/0
ip address 192.168.152.254 255.255.255.0
ip nat inside
standby version 2
standby 152 ip 192.168.152.1
standby 152 priority 110
standby 152 preempt
ip virtual-reassembly
interface GigabitEthernet0/0/1
ip address 103.xxx.xxx.133 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route 0.0.0.0 0.0.0.0 103.xxx.xxx.132 track 100
ip route 0.0.0.0 0.0.0.0 192.168.152.253 10
ip sla 100
icmp-echo 8.8.8.8 source-interface GigabitEthernet0/0/1
frequency 20
ip sla schedule 100 life forever start-time now
RouterB
ip address 192.168.152.253 255.255.255.0
ip nat inside
standby version 2
ip address 113.xxx.xxx.233 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route 0.0.0.0 0.0.0.0 113.xxx.xxx.232  5
ip route 0.0.0.0 0.0.0.0 192.168.152.254 10
Please correct me if Im wrong.
7 Replies 7
Dennis Mink
on your router A, does ip route 0.0.0.0 0.0.0.0 192.168.152.253 10  take over when you shut interface GigabitEthernet0/0/1?
Please remember to rate useful posts, by clicking on the stars below.
Hi Dennis,
Yes, when I shutdown the G0/0/1, the route 0.0.0.0 0.0.0.0 192.168.152.253 will take over. But when i no shut the G0/0/1, the route still stick to 0.0.0.0 0.0.0.0 192.168.152.253.
The problem is not your config, that is fine. Now the failover will not be active because you can still reach the 8.8.8.8 when the interface G0/0/1 is still up or down.
What I have made for this situation is create an EEM script to remove the primary static route.
This a complement of your config.
delay down 3
event manager applet FAILOVER-INTERNET
 event tag prim syslog occurs 1 pattern "%TRACKING-5-STATE: 100 rtr 100 state Up->Down"
 event tag sec syslog occurs 1 pattern "%TRACKING-5-STATE: 100 rtr 100 reachability Up->Down"
 trigger
  correlate event prim or event sec
 action 1.0 cli command "enable"
 action 2.0 cli command "no ip route 0.0.0.0 0.0.0.0 103.xxx.xxx.132 track 100"
 action 3.0 cli command "exit"
 action 4.0 cli command "write memory"
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio,
Do you have any example EEM script for me to refer?
Yeap, hope the config is useful. The sintaxis for the applet could be different for some devices.
You also could remove this line ip route 0.0.0.0 0.0.0.0 192.168.152.254 10 and add it to the script to create it once the EEM is triggered.  Example:
 trigger
 action 3.0 cli command "ip route 0.0.0.0 0.0.0.0 192.168.152.254 10"
 action 4.0 cli command "exit"
 action 5.0 cli command "write memory"
Hi Julio,
Thanks and I will test it out later. :)
You are welcome Tommy, remember the sintaxis could be different per device, it is related to a 6500 but the essence is that.
