WIC-4ESW 4-Port
sdovale13
I have cisco 1720 router that was previously installed with a serial interface. The router is used to connect to an ISP leased line. As the ISP changed his equipment, I now need to install a WIC-4ESW 4-Port into my router. So I would like to know which ios version I would exactly need in order to have the card recognized and working. I also need to be able to configure encapsulation.
Thx for your help
5 Replies 5
bretjaquish
Level 3
Level 3
Here is a link for what you need:
WIC-4ESW
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a00801c749d.html
Requires: IP or IP Basic
First Software: Cisco IOS Software Release12.3(2)XC (this is an early deployment release that will merge into Cisco IOS Software Release 12.4T)
Kevin Brennan
Hi Stephane,
The HWIC-4ESW isnt supported in the 1700 Series. The linked sheet shows the platforms that it is supported in.
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/product_data_sheet0900aecd8016bf0b_ps5855_Products_Data_Sheet.html
The WIC-1ENET might do the job for you though.
Have a look here:
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a0080088714.html
Kevin
Kevin,
Stephanie has a WIC-4ESW, not a HWIC-4ESW. The WIC-4ESW is support in her platform.
Bret
Bret,
Well spotted, my mistake!
Kevin
No problem! I had to check myself again to see if I overlooked that. Wouldn't have been the first time for me!
