WIC Interface
magibson2
I have a CISCO 1700 series router and I would like to remove the CSU/DSU WIC & add a WIC-1ENET is this possiable without having to upgrade the IOS Firmware.
2 Accepted Solutions
skarthic
Please check the link for software requirements:
http://www.cisco.com/en/US/docs/routers/access/1700/software/feature/guide/cn1ENET.html#wp1003555
If the software supports the WIC there shd be no other issues.
Subramaniya Karthic
Please rate posts if it was helpful.
Thank you.
skarthic
Subramaniya Karthic
Thanks so much when I get back to my lab I will check the version.  Thanks again so much.
Thank you.
Where do you rate at.
