Wildcard Mask
Jean-Luc1995
what is the difference a wildcard mask 1 and a wildcard mask 0
omz
0-bit = match
1-bit = ignore
'Don't care bits' are represented by binary 1's whilst the 'Do care bits' are represented by binary 0's. The exact opposite of the subnet mask. Taking 192.168.1.32/27 as an example. Subnet mask - 255.255.255.224
4th octet in decimal
32
4th octet in binary
0 0 1 0 0 0 0 0
4th octet mask in decimal
224
4th octet mask in binary
1 1 1 0 0 0 0 0
Now the 4th octet wildcard in binary
0 0 0 1 1 1 1 1
Now the 4th octet wildcard in decimal
31
   255.255.255.255Wildcard mask -  0.0.0.31
- 255.255.255.224
       0.    0.    0.  31
omz
0-bit = match
1-bit = ignore
32
4th octet in binary
0 0 1 0 0 0 0 0
224
1 1 1 0 0 0 0 0
0 0 0 1 1 1 1 1
31
- 255.255.255.224
       0.    0.    0.  31
thank you appreciate the help
