Will 6509 load-balance multiple T1s?
neonetsup
Hello group,
Plan to migrate from a 7513 with 2 pa-mc2t3 cards into our 6509 using those cards w/FlexWAN modules. We have some sites with multiple T1s connecting to the 7513 -- using HDLC and whatever default load balancing it provides.
Will the 6509 behave the same way in terms of balancing multiple Ts?
IOS on the 6509: 12.2(18)SXD3
Thanks for any input!
thisisshanky
Level 11
Level 11
Yes, CEF and static default routes.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
