02-25-2022
10:39 AM
- last edited on
02-25-2022
10:05 PM
by
Translator
Hi All,
I have configured BGP on R1,R2 & R3.
R1 & R2 : IBGP : (ASN: 65100)
R3 - ASN: 64519
R2 advertised 192.169.1.0/24 network.
R1 & R3 received that route.
If i shutdown the direct link from R1 to R2(Interface (G 0/1), R1 is not able to learn route 192.168.1.0/24 through R3.
Can someone explain, why ?
Routes learned:(When interface is UP)
Route not learned(when interface is shutdown)
Solved! Go to Solution.
02-25-2022 10:54 AM - edited 02-25-2022 11:15 AM
Hi @Cisconew ,
The route is rejected by R1, because its own AS number (65100) is contained in the update AS PATH. The AS PATH loop prevention mechanism will not allow that.
02-25-2022 10:48 AM
what is 192.168.1.0, an (loopback) interface, a static (null) route ?
02-25-2022
10:58 AM
- last edited on
02-25-2022
10:07 PM
by
Translator
It's a
loopback interface ip address>
Hi @Cisconew ,
02-25-2022 10:58 AM
Thank you: I understand AS_Path loop prevention Mechanism.
03-05-2022 11:27 PM
AS PATH loop defense mechanism
