Work Around for suspected SSH traffic drop by ISP
Learner09
I am facing SSH connection failure between a source and destination using Public IPs over internet, It seems SSH traffic is blocked somewhere in the middle. Tried to telnet destination IP on port 22 but fails, while with some other TCP ports it's successful. SSH traffic was not reaching the other side. Source IP is a public IP that is static natted(on the cisco router) to one of the inside server private IPs. Is it possible to overcome this issue with a workaround like a GRE tunnel between source and destination, and forcing SSH traffic to pass through the tunnel. If possible, will the static NAT be a problem? Suggestions please. Thanks in advance.
Hello
Is ssh enabled on the destination device and is there any ACL or Control plane policing  negating access to the vty lines?
If the host is behind a NAT then is port forwarding enabled for ssh for that particular device?
Kind Regards
Paul
Thank you for your reply, yes ssh is enabled on the destination device and there’s no ACL blocking it. For the second question, destination is not behind NAT, source host is port forwarded for ssh.
If the device you need to access via ssh is ASR then it can ssh port is not 22 and it use other ssh port.
Force router using port 22.
MHM
Ruben Cocheno
@Learner09
To make sure that your config is right, i suggest you run a packet capture at the source/destination (ideally at the edge) and confirm then where the traffic is getting dropped.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
