WS-3560X-48T-S , After format flash , IOS file reinstall failed, Error MSG "Boot process failed "
LiWenbin2008
1.When the switch is POSTing, I press the MODE button. At the rommon mode, I use the " format flash:" to format the flash.
2.Then I take a USB Device insert into the switch, and take "format usbflash0:" to format the USB device.
3. I copyed the "*.bin" to the USB by my PC , and  then copy the IOS file to the switch.
4.After type the "boot" , a long time later , the cli common show the error log "Boot process failed".
Anyone can help me ? Thanks. My IM(Tecent QQ 443408372)
I have tested the XMODEM way to update the IOS ,  Failed ... ,and the same error.
I have download the *.lic file from the cisco.com , I don't know if it's related?
INFO
switch: set
BAUD=115200
BOARD_CONFIG_REV=0
BOOT=flash:c3560e-universalk9-mz.150-2.SE.bin
CLEI_CODE_NUMBER=COMJN00ARC
DAUGHTERBOARD_ASSEMBLY_NUM=800-32786-02
DAUGHTERBOARD_SERIAL_NUM=FDO163501E8
DEFAULT_ROUTER=192.168.1.101
MAC_ADDR=FC:99:47:EC:36:80
MODEL_NUM=WS-C3560X-48T-S
MODEL_REVISION_NUM=A0
MOTHERBOARD_ASSEMBLY_NUM=73-12556-06
MOTHERBOARD_REVISION_NUM=A0
MOTHERBOARD_SERIAL_NUM=FDO16341YFP
SDM_TEMPLATE_ID=0
SWITCH_PRIORITY=1
SYSTEM_MTU=1530
SYSTEM_SERIAL_NUM=FDO1604P06F
TAN_NUM=800-31330-03
TAN_REVISION_NUMBER=B0
VERSION_ID=V03
boot=flash:c3560e-universalk9-mz.150-2.SE.bin
-- MORE --
switch:
switch: boot
Loading "flash:c3560e-universalk9-mz.150-2.SE.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:c3560e-universalk9-mz.150-2.SE.bin" uncompressed and installed, entry point: 0x3000
executing...
Loading "flash:/c3560e-universalk9-mz.150-2.SE.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:/c3560e-universalk9-mz.150-2.SE.bin" uncompressed and installed, entry point: 0x3000
executing...
Boot process failed...
switch:
Nothing wrong with the SET values.  As a matter of fact, you didn't have to use XModem because you could boot an IOS on a 3560X by using USB.  It would've been alot quicker that way.
10 Replies 10
LiWenbin2008
Anyone have the same problem? The guide in cisco.com, I have tried, failed again.
The IOS you've uploaded could be corrupt.
Download the IOS again (from the Cisco website) and compare the MD5 hash.
I have checked it , it's the right IOS.
There's the *.bin file in the flash only, is this enough for boot ?
Yes, you can boot the BIN file.
About the "SET" values , any wrong? Thanks
I have tested "boot usbflash0:3750.bin" , failed either , the same error.
In cisco.com IOS download page, there are some *.tar files with the same version.
Is there any differences?
TAR files is the ZIP equivalent in UNIX.  Inside a compressed TAR file is the BIN file and the HTML files.
Of course this command will fail.  Firstly, the filename is wrong and secondly, you're booting a 3750 IOS from a 3560X.
Thanks leolaohoo, it's just a example.
I have solved the issues with another version IOS:c3560e-ipbasek9-mz.122-58.SE2.bin.
I don't know what's the difference between c3560e-ipbasek9-mz.122-58.SE2.bin and c3560e-universalk9-mz.150-2.SE.bin, why the c3560e-universalk9-mz.150-2.SE.bin cann't boot the system?
