Bookmark
Subscribe
2166
ws-x6704-10ge query
Hi Team,
I would like to know if we can use the following card i.e. WS-X6704-10GE along with SUP-2T which will be configured in VSS.
This line is supported with SUP-2T, however not sure if the sup 2t will be configured in VSS. If any supporting document can be provided for the same , that would be great.
If this is supported than whether i would be getting line rate/non blocking capacity with WS-X6704-10GE. Since SUP-2T provides 80 Gbps bandwidth per slot.
K Subin
2 Accepted Solutions
Giuseppe Larosa
Hello Subin,
if equipped with a DFC4 or a CFC the WS-6704 should be supported also in the VSS
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/15.1SY/release_notes.html#wp4765684
and
>> Switching modules with a CFC, DFC4, or DFC4XL support VSS mode.
sup2T config guide
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/15.1SY/config_guide/sup2T/virtual_switching_systems.html#wp1053927
However, the WS-6704 cannot be used to build the VSL link as it misses the ASIC that support the VS protocol.
The VSL HW requirements are:
VSL Hardware Requirements
The VSL EtherChannel supports only 40-Gigabit and 10-Gigabit Ethernet  ports. The ports can be located on the supervisor engine (recommended)  or on one of the following switching modules:
WS-X6904-40G-2T
WS-X6908-10GE
WS-X6816-10T-2T, WS-X6716-10T
WS-X6816-10G-2T, WS-X6716-10GE
Hope to help
Giuseppe
Hello Subin,
the WS-6704 has two connections to the fabric at 20 Gbps / per direction
>>Dual switch-fabric connections:
Fabric Channel #1: Ports 3 and 4
Fabric Channel #2: Ports 1 and 2
The Sup2T runs the connections in backward compatibility mode as it detects a WS-67xx mode.
>> Each channel can operate at either 40 Gbps to  support the new WS-X69xx linecards, or 20 Gbps to provide backward  compatibility for WS-X67xx and WS-X68xx linecards
from sup2T Architecture white paper
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/white_paper_c11-676346.html#wp9001559
So the WS-6704 will get 2 X20 Gbps per direction dual connection to the Sup2T crossbar switching fabric.
But this is enough to run non blocking, and actually the module runs non blocking also on a sup720 chassis.
Hope to help
Giuseppe
5 Replies 5
Giuseppe Larosa
Hello Subin,
see
and
sup2T config guide
WS-X6904-40G-2T
WS-X6908-10GE
Hope to help
Giuseppe
Guiseppe,
Thanks a lot for the reply. Could you please provide the answer for the last part also i.e. whether i would be getting line rate/non blocking capacity with  WS-X6704-10GE. Since SUP-2T provides 80 Gbps bandwidth per slot.
Hello Subin,
Hope to help
Giuseppe
Thanks a Lot guiseppe.....
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
BTW, if full bandwidth from fabric to 10g port is your objective, you have a coupld other options.  First, the other 10g cards often offer a "performance" mode, where they deactivate ports so you will obtain full fabric bandwidth to 10g ports.  Second, if you carefully review documentation on oversubscribed 10g line cards, you'll find what ports share fabric bandwidth.  If you only use specific ports, you can reduce or eliminate oversubscription to specific ports.
BTW, I recall when the 6702 and 6704 were both available, the former was documented as truly non-oversubscribed, the latter was not.  If I remember correctly, the fabric actually provided just a smidgen less bandwidth then 20g per channel.
Also keep in mind, as it's not uncommon to have multiple ingress ports sending to the same egress port.  I.e. the port itself can congest.  Assuming this is transient, the latter higher density 10g cards provide more port buffering memory.  In other words, something like a 6708 might perform better than a 6704 especially if running in performance mode.
