ZBF problem with remote VPN via virtuel interface on a 2911
lars.arler
Hi again and thanks in advance.
I had some good help from Georg Pauwen before and he found som issues and directed me in the right direction but I'm still stocked with this problem even after implementing his fixes
My Zone Based Firewall setup.
My problem is still that when I connect remotely via VPN.
  • I connect with some log issues to my router and data flows through VPN
  • %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Aggressive mode failed with peer at 77.241.128.136
    %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to down
    %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
    %FW-6-DROP_PKT: Dropping Unknown-l4 session 80.XX.XX.126:0 80.XX.XX.100:0 on zone-pair INTERNET-TO-DMZ class class-default due to  DROP action found in policy-map with ip ident 0
    %IP_VFR-7-FEATURE_DISABLE_IN: VFR(in) is manually disabled through CLI; VFR support for features that have internally enabled, will be made available only when VFR is enabled manually on interface Virtual-Access2
  • I have full access to the Internet (Outside) through Remote VPN
  • But can't connect to my servers ( DMZ)
  • %FW-6-DROP_PKT: Dropping Unknown-l4 session 80.XX.XX.126:0 80.XX.XX.100:0 on zone-pair INTERNET-TO-DMZ class class-default due to  DROP action found in policy-map with ip ident 0
    Indicates that my policy maps in zone-pair INTERNET-TO-DMZ are wrong or inadequate.
  • I can't even ping the servers the DMZ via the VPN connection. but the default-router 80.xx.xx.97 answer the ping request.
My Server (DMZ) and VPN are on the same IP range, not that I think matters.
I have read CISCO ZBF guide many times now, but I really can't figure out what seems to be the problem. I even deleted all ZBF setting and tried to start all over again but with no luck.
So I would be thankful for a pair of keen eyes to see if I have an obvious mis match somewhere in my config...
Key elements in my config
R2911
boot system flash c2900-universalk9-mz.SPA.154-3.M.bin
ip dhcp excluded-address 192.168.100.1 192.168.100.49
ip dhcp excluded-address 192.168.50.1 192.168.50.49
ip dhcp pool VLAN200
 network 80.xx.xx.96 255.255.255.240
 dns-server 8.8.8.8 4.4.4.4
ip dhcp pool VLAN100
 network 192.168.100.0 255.255.255.0
 default-router 192.168.100.1
 dns-server 192.168.100.1
ip dhcp pool VLAN50
 network 192.168.50.0 255.255.255.0
 default-router 192.168.50.1
 dns-server 192.168.50.1
class-map type inspect match-any CLASS_CRYPTO_IPSEC_PASS
 match access-group name IPSEC_TRAFFIC
class-map type inspect match-any CLASS-L4-IP
 match protocol icmp
 match protocol tcp
 match protocol udp
class-map type inspect match-any CLASS-APPLE-REMOTE-DESKTOP
 match access-group name APPLE-REMOTE-DESKTOP
class-map type inspect match-any CLASS-APPLE-AFP
 match access-group name APPLE-FILE-SHARING
class-map type inspect match-any CLASS-INTERNET-TRAFFIC
 match protocol http
 match protocol https
 match protocol dns
 match protocol icmp
class-map type inspect match-any CLASS-FTP
 match protocol ftp
 match protocol ftps
class-map type inspect match-any CLASS-SSH
 match protocol ssh
class-map type inspect match-any CLASS-IMAP-SMTP
 match protocol imap
 match protocol smtp
class-map type inspect match-any CLASS-ALLOW_ALL_TRAFFIC_THROUGH
 match access-group name ALLOW_ALL_TRAFFIC_THROUGH
policy-map type inspect POLICY-(PRIVATE-->DMZ)
 class type inspect CLASS-FTP
  inspect
 class type inspect CLASS-SSH
  inspect
 class type inspect CLASS-APPLE-REMOTE-DESKTOP
  inspect
 class type inspect CLASS-APPLE-AFP
  inspect
 class type inspect CLASS-INTERNET-TRAFFIC
  inspect
 class type inspect CLASS-IMAP-SMTP
  inspect
 class type inspect CLASS-L4-IP
  inspect
 class class-default
  drop log
policy-map type inspect POLICY-(SELF-->INTERNET)
 class type inspect CLASS_CRYPTO_IPSEC_PASS
  pass
  inspect
 class class-default
  drop log
policy-map type inspect POLICY-(INTERNET-->SELF)
  pass
  inspect
 class class-default
  drop log
policy-map type inspect POLICY-(PRIVATE-->INTERNET)
  inspect
  inspect
  inspect
 class class-default
  drop log
policy-map type inspect POLICY-(INTERNET-->DMZ)
  inspect
  inspect
  inspect
 class class-default
  drop log
policy-map type inspect POLICY-(DMZ-->INTERNET)
 class type inspect CLASS-ALLOW_ALL_TRAFFIC_THROUGH
  inspect
 class class-default
  drop log
zone security PRIVATE-ZONE
zone security INTERNET-ZONE
zone security DMZ-ZONE
The Green zone-pairs works fine
zone-pair security PRIVATE-TO-DMZ source PRIVATE-ZONE destination DMZ-ZONE
 service-policy type inspect POLICY-(PRIVATE-->DMZ)
zone-pair security PRIVATE-TO-INTERNET source PRIVATE-ZONE destination INTERNET-ZONE
 service-policy type inspect POLICY-(PRIVATE-->INTERNET)
zone-pair security INTERNET-TO-DMZ source INTERNET-ZONE destination DMZ-ZONE
 service-policy type inspect POLICY-(INTERNET-->DMZ)
zone-pair security DMZ-TO-INTERNET source DMZ-ZONE destination INTERNET-ZONE
 service-policy type inspect POLICY-(DMZ-->INTERNET)
zone-pair security SELF-TO-VPN-INTERNET source self destination INTERNET-ZONE
 service-policy type inspect POLICY-(SELF-->INTERNET)
zone-pair security VPN-INTERNET-TO-SELF source INTERNET-ZONE destination self
 service-policy type inspect POLICY-(INTERNET-->SELF)
crypto isakmp policy 150
 encr aes 256
 authentication pre-share
 group 2
crypto isakmp client configuration group SAS-VPN
 key XXXXXX
 dns 208.67.222.222 208.67.220.220
 pool REMOTE-VPN-CLIENTS
 acl 101
crypto isakmp profile SAS-VPN-PROFILE
   match identity group SAS-VPN
   client authentication list userauthen
   isakmp authorization list userauthen
   client configuration address initiate
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set SAS-VPN-1 esp-aes 256 esp-sha-hmac
crypto ipsec profile SAS-VPN-VTUNNEL-PROFILE
 set security-association lifetime kilobytes disable
 set security-association lifetime seconds 86400
 set transform-set SAS-VPN-1
 set isakmp-profile SAS-VPN-PROFILE
interface GigabitEthernet0/0
 description ISP WAN (Wide Area Network)
 ip address 87.XXX.XXX.190 255.255.255.252
 ip nat outside
 ip virtual-reassembly in
 zone-member security INTERNET-ZONE
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description LAN (Local Area Network)
 ip address pool VLAN100
 ip nat inside
 zone-member security PRIVATE-ZONE
 duplex auto
 speed auto
interface GigabitEthernet0/2
 ip address pool VLAN50
 ip nat inside
 duplex auto
 speed auto
 interface Vlan200
 description HWIC-4ESW_LAN - SERVER PARK
 ip address 80.XXX.XXX.97 255.255.255.224
 ip nat inside
 zone-member security DMZ-ZONE
interface Virtual-Template1 type tunnel
 description Virtuel VPN Forbindelse
 ip unnumbered GigabitEthernet0/0
 ip nat inside
 tunnel source GigabitEthernet0/0
 tunnel mode ipsec ipv4
 tunnel protection ipsec profile SAS-VPN-VTUNNEL-PROFILE
router eigrp 100
 network 80.0.0.0
 network 87.0.0.0
 network 192.168.0.0
router ospf 123
 network 80.0.0.0 0.255.255.255 area 0
 network 87.0.0.0 0.255.255.255 area 0
 network 192.0.0.0 0.255.255.255 area 0
ip local pool REMOTE-VPN-CLIENTS 80.xx.xx.123 80.xx.xx.126
ip forward-protocol nd
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 87.63.227.189
ip access-list extended ALLOW_ALL_TRAFFIC_TROUGH
permit ip any any
ip access-list extended APPLE-FILE-SHARING
 permit tcp any any eq 427
 permit tcp any any eq 548
ip access-list extended APPLE-REMOTE-DESKTOP
 permit tcp any any eq 22
 permit udp any any eq 3283
 permit tcp any any eq 5900
 permit udp any any eq 5900
 permit tcp any any eq 3283
ip access-list extended EIMS-MAILSERVER
 permit tcp any any eq 587
permit tcp any any eq smtp
permit tcp any any eq 143
ip access-list extended EIMS-MAILSERVER-ADMIN
permit tcp any any eq 4199
ip access-list extended IPSEC_TRAFFIC
 permit ahp any any
 permit esp any any
 permit udp any any eq non500-isakmp
 permit udp any any eq isakmp
access-list 1 permit 192.168.100.0 0.0.0.225
access-list 1 permit 192.168.50.0 0.0.0.255
access-list 123 permit esp any any
access-list 123 permit udp any any eq non500-isakmp
access-list 123 permit ahp any any
access-list 123 permit udp any any eq isakmp
lars.arler
I finally found a solution to my problem ;-)
My (DMZ) and (Remote VPN) are on the same IP range, BUT in different ZONES
- AND that is a problem !! - when (Remote VPN) is in the INTERNET-ZONE.
So I had to move (Remote VPN) into the (DMZ-ZONE) and then everything works... And my Remote VPN users is trusted users ..
Or keep (Remote VPN) in the (INTERNET-ZONE) and then give it a IP range of it ovn (f.ex. 10.10.10.0 - 255.255.255.0) TESTED and works to
 ip nat inside
But anyways thanks to you all for taking your time to review my config.
lars.arler
 ip nat inside
