Zoom-meetings QoS and NBAR
Leonid Voronkin
Hi all.
I have found NBAR2 Protocol Pack 33.0.0 have new protocols one of this is zoom-meetings
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/qos_nbar/prot_lib/config_library/pp3300/nbar-prot-pack3300/rel-notes-protocol-pack-33-0-0.html
I have Protocol Pack 38.0.0 but I cant find how to match it. Match protocol does not consist this name
Has anyone done it before?
________________________________________________________
Если ответ понравился, ставь звёздочку. Если ответ помог решить твою проблему, утверди его в качестве решения
12 Replies 12
not sure why it is not listed in the higher pack...
I searched around and it looks like ZOOM uses the ports below:
Protocol Ports Source
TCP 80, 443 All Zoom Clients and Meeting Connector
TCP 443, 8801, 8802 All Zoom Clients
UDP 3478, 3479, 8801, 8802 All Zoom Clients
Yes, I know it. It require not only ports but also a big list of service subnets. Of course I can do it.
But I want to understand how to do it with NBAR. Especially if there is a possibility
Joseph W. Doherty
Did you try typing the protocol name, as listed in the release notes? (It might be there like a hidden command, although that would be a bug.)
Have you contacted TAC?
Yes, I tried to enter this argument. It does not work. There is no hidden commands.
No, I have not contacted with TAC. I think it is to early. May be I miss something.
If it's supposed to be in the NBAR version you have, it's not too soon to contact TAC. (Every see a new IOS released a day or so after one just released?)
it is listed in pack 44, is it an option to use that one ?
Hi. I tried to install packs 44 and 45. But i still don't see "zoom-meetings". Where did you find it?
Or may be it is required reload the router after packet installation? I have not found mention of it for NBAR pack installation process
here is the link I am referring to. Open the release notes for e.g. pack 44 and click on the column containing the letter 'Z' on the left...
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/qos_nbar/prot_lib/config_library/nbar-prot-pack-library.html
Which platform do you have (not sure if you have already mentioned that) ?
It is listed already in 38 pack.
I though you found it in CLI
I use ISR4431 IOS XE16.9.4
I guess my point is: it might be listed, but that might be an error in the documentation. If possible, try and actually install pack 44.
As I said above I have already installed pack 44. But still I cant find zoom
sorry, didn't see that you had already installed 44. I couldn't find any mention of having to reboot the router either...'show ip nbar version' should show you the current installed and active one.
I am looking at the NBAR Protocol Pack Auto Update procedure, I don't know if the protocol packs may be installed in a different way using this, you might want to give it a try...
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/qos_nbar/configuration/xe-16/qos-nbar-xe-16-book/nbar-pp-auto-upd.pdf
